This individual notification for contacts thing
I definitely didn't buy it. Tried to post a ss of my settings but I can't see how to do it on here.
do you use an ad blocker? I do, but I paid for the app so the badge.
I do, but the ad looks like a text, so neither blokada nor adguard can block it. Plus, it should still show the ad setting.
I just installed the side load pro version, as you said, it reads pro user.
I don't get it.
Ok, I got it.
You two were right, there is a free trial, though it doesn't state that. I installed it long ago, uninstalled it, and recently installed it again.
I just installed it on my girlfriend's phone.
Ok, I got it.
Great. Now I have ads coming to look forward to....LOL
Yes, it's a 14 day free trial and after that you get to decide whether or not to buy the pro version. I've just gotten that notice since I also don't appreciate the same notification for every text message
I don't know why people can't just answer a question, not everybody reads everything everyday all day, so it's very easy to miss something.
The answer to your question is that you will need to use a different messaging app until Samsung fixes this. I'm using Android msgs & all you do is open app to person you want to text, upper right corner 3 dots, people & options then you should be able to find the option to set the text tone.
I find it unhelpful since the only way to make it go away is to delete it, over and over and over and over. none of my other apps find it necessary to bot me to give release notes. which means it's not necessary, but rather an intrusion into my space. it's a personal preference thing.
I see that bot maybe once every 2 months. It's a non issue for me. Seems every app that updates, issues a "what's new in the update" screen when you first launch it. Android Central is big on this. A simple tap of the back button and it's gone.
Post #2 is a link to a thread about the very same topic as this thread. The 2nd post in that thread says use a different sms app, as does the 3rd post in this thread.
I'm sure why you're so bent out of shape when the question was answered way before your post.
Yes sir, you are right, the link does go to a different thread saying this, but, it's much easier to just read the answer. The rest of your post is incorrect, all there is , is a bunch of arguing about whether a different app is free or not. Don't worry yourself about my shape, I'm fine....Have a blessed day!
jesper76
