Thunderbolt Issues/Solutions
Status
Not open for further replies.
You cleared out the old notification and had someone send you a new one and you still get 2?
By clearing out I mean pull down notification bar and press clear.
Yep I did that and still get two
sent from my HTC Thunderbolt using Tapatalk
how do i take snapshots without root? i use drocap but cant use it now cas it not rooted yet
ok its not a text message icon it looks like an mail icon dat comes up but it says new messages
pull down the notification bar and click whatever the notification is, that will open it up and you will know what it is
i clicked it and it doesn't open up nuffin my notification bar just closes i tried almost everything its gettin annoying now lol
try uninstalling handcent and texting yourself, see if you get a notification
also, what color is the symbol?
I installed Handcent, but decided that i didnt want to spend the time to customized it. So i uninstalled it. I might try it again in a week or so, but the part that interests me most is that it will split messages over 160 characters. Does anyone know if the stock HTC messaging app does this? All of my friends right now have Verizon... This is just incase i message someone off Verizon, i dont want to spend the time to split the message myself. Thanks guys!
this what it looks like
yeah , try what i said, uninstall handcent and send a text to yourself and check it,,,and remove advanced task killer android does not need it and it will cause more issues than it will help
imma try that and and i only have that for wen apps freeze up i dont use it to constantly kill apps
ok i sent a text to myself with handcent unstailled and it shows i have 2 messages but i only sent one text message
I cannot get Swype to work in the messaging app. Well, it works but it does not put in spaces between words. It works as it should in email, but not in messaging. I have checked the settings and they are correct. Anyone else? I love me some swype and have been waiting patiently to get rid of my eris and get it working on my TB but no go.
Yeah, I'm getting that too. Swype works fine everywhere except the Sense messaging app. There, there's no auto-spacing and no auto-caps. Haven't figured out any solution to that yet, except to type texts in another app - I use SMS popup, and typing texts in it's quick reply box works fine.
Status
DanishDanuu
