[Tool] Root 2.11.605.9 and .19, no downgrade or data wipe!
Re: Tool to bypass downgrade to get S-OFF, no data wipe!
i have unlock and root on the device but o need to put RUU ROM on it and i can't...
First of all, thank you for developing this tool!! I'm semi-literate when it comes to this stuff, and your tool definitely helped make it easier. However, I do have a few recommendations (based on my experience).
- I downloaded your file yesterday (3/29), and it still didn't load SU.zip onto the SD card. So, I manually installed it with no problem.
- Similar to a previous post, your pop ups during Revolutionary led me to reboot rather than boot to Recovery. Maybe that was because SU.zip didn't load initially, but I really wouldn't know. I did end up going back to the Revolutionary posting here:
http://forums.androidcentral.com/th...ow-root-unroot-thunderbolt-revolutionary.html
and picked up at Step 9. From there, everything worked fine.
Like I said, I may've taken a wrong turn somewhere to get me to that spot, but I worked through it. THANK YOU for the tool!!!
Thanks for the recommendations! I'll get right on that :D
Uploading fixed version now ... ;)
Reactions: Devils Advocate
Re: [Tool] Root 2.11.605.9, no downgrade or data wipe!
you are the man!!! I've tried everything since upgrading and had no luck until now!! worked like a charm!!!
THANK YOU!!! :)
How long does the root process take using this method?
What are fastboot drivers? I searched this forum, but there were so many results I didn't know where to begin.
They are the drivers revolutionary needs to run. This program aska if they are installed, just say no and it begins the install.
Sent from my BAMF'd Thunderbolt
Hi all! This is a quick tool I made that will bypass your need to downgrade from 2.11.605.9 to get S-OFF. It uses the fre3vo exploit by TeamWin/ Agrabren . I take no credit for this method.
It will:
Get root
Open Revolutionary.io and the Revolutionary exe
Give you the option to install the fastboot drivers
Give you instructions on what to do
This means that you will not have to deal with large files, and you will not lose any data.
Happy rooting!
File: Goo-inside.me Downloads - Downloading DowngradeBypass.zip This file at goo.insideme is coming out as code and not a .zip file
MD5 is on download page.
All you do is download this, unzip it (very important!), and run the RUN-ME.bat. Just make sure to read and follow all directions in the program carefully.
Please copy and paste the beta code for Revolutionary when that step comes along (I tell you how in the tool), because if it gets put in wrong you will need to manually start Revolutionary from the support_files folder.
Also, I would like to add... this. :P
Click to view quoted image
I dont know if there is an issue with the file host site, but every time i try to DL the zip file I get code instead.
This is some of what I see when I try to download the file
PKr?~@?m?? RUN-ME.bat?Vm??0?N?8?&^Æ?71AE%?a??kL????]???޳nx???M?=??9Oy?Q?@???V??????[?[??|?I&c?+%, ?^n4?^?)3?ݚ?a6a?q?`?4U?~_s????sX?>O???bq?n??e? n??A?C]wm,?????L?-:????`?? ??????3?Kԝ??t4[^?˽S[l ?4?? ?-?M帱?Yun??????s? r??]??(L??r?? ?R????Z?????L??>?\??*%輑2?i? V[?O??I#?0a??@?l{?%? ?k??v??ߕ?|?ە@f?C?U?!M?D ?Q??AI??V???*?d+?N`Y?=?!D1j??0?U??p????~?`???E?;*ݢ??aT??x?Ma? ?jE]??a?L?MPw?j8???»? ????6??? ?^ ??P???&???+?,Ě?L??fL?_—O??7p~8}???p??Exq{??q>?·?ɇ???B?_?]???i????) ]?>???Fh4??@?fE.?*%?GI?V$e??l??\:W??kƋN9?Ÿ???_?I{?H?+??cE4y???۲? ???M*?I???C?????I?w??}??2C?R????d ?FA????)M???$$???ˇGù{?"?L??=???_[)? ?z?-&?D(?u???N?͆f3?????:??|g%\ο_?>???D????<??(????qS$7?`?W??۳hB? g?;%2˕d:/H???W?[?i?㏔??b?O?|????D???/1?;??: ?????O凉??ȴ)&ں??<I?I*?˷?5#+r???l?̈??R??????)??/@?\z$vFie??PKo?n@support_files/PK?$@??Dֿ63?support_files/adb.exe?]{xSE?i? ?E+? ?H???????nHxDc??Q,[6?r??? ?`eD?U?U??G ????(?uE??*?a-P????{o??]w??~??Μ9sΙ3gΜy0qF??,I???QI*?ğC??"??|yYgiS???(5Mx??)???Xx?}w?????;??{?}????̸?po???f???θ?yw?ԩC ?씤 &?$?>:^???tKI??ڙ:???I M??8????.xکRQ'ޓ?&N??WҞ,??|?_?ŏ??:??R?M??? ?߹؏?m??8A?Ws"L?Λ럋?UIĻ?Ǔ?bmU1?~?x?d??????s ???? R?InW?w???f?246\ ??so'Z ?1??rZ?HI??? ?F^? ?\?????{2?{????$?.s8??N????? ??8?????o?X<?/7?&?r?P???N?????? ??/??<????p7??_}48?ܰ?????p???? ?r~?\?G/?9h?,L???xl?N??|?qg6?NK?aUR??@?<8rt??];??]?????o?????&??7? ?`???? ?Ej??&?????????U(??? s?Jz??^$?N??)?{????]C=??"?? a?U??X??,?@Ïwr?Pc ??)??L?"?D?Q?Hپ; d?C???"?#??W`B?# ?Ph5}g??p?3|??!??|???^?i?خ^?????M??&n????j??ߍ?
In a HTML file instead of a zip file
Oh!
That means you're downloading the webpage, go to the download page and wait about 20 secs and see what happens
gulbhahar36
