[Tool] Root 2.11.605.9 and .19, no downgrade or data wipe!
Re: [Tool] Root 2.11.605.9, no downgrade or data wipe!
??? Im confused, I clicked your link, then waited 10 secs as its a free host site and I dont want to join. Then at the top the I clicked to download the file and what downloaded was what appeared to be a hypertext file full of strings of code.
No I am having an issue with the beta key being invalid even though it matches perfect. Is it because ADB is recognizing it as the mecha and my option is for TBolt?
Mecha is the tbolt, I'd say try to re-generate the beta key
yeah mecha was the code name. I tried to regenerate three times is it because I already DL revolutionary to my desktop the same location as your bypass tool.
I'm not sure what's up, you're copy and pasiting it right?
I can copy but it wont let me paste into the CMD prompt for some reason?
The popups told you how
(To paste it, right click the title bar of the Revolutionary window then click edit then click paste.)
Reactions: tropper
you provide a complete tool the one tip I leave everyone who follows me dont do it half asleep and read EVERY instruction you provide.
Now Im gonna get some coffee and play with my phone. Thank You againg Trter
haha no problem
This worked great! Just in time too. Keep up the great work!
Sent from my HTC ThunderBolt using Tapatalk
Okay. I'm giving this a whirl.
I've gotten my beta code but I cannot seem to be able to paste it. I'm using a laptop with just a touch pad and no mouse, so I cannot right click and the dropdown menu button does nothing.
I tried manually typing in the beta code but repeatedly get an "invalid" message.
Can anyone assist?
Thanks.
Joe
if you copy the code from the websight and then click in the upper left hand side of the command prompt box there is the option to edit and then paste.
Yup...just figured that out.
Thanks for the reply.
I do believe that my Thunderbolt is now rooted.
It said it rooted successfully, but my phone still has not root. Please help. Thanks in advance.
paulmloucks
