[Tool] Root 2.11.605.9 and .19, no downgrade or data wipe!
Re: [Tool] Root 2.11.605.9, no downgrade or data wipe!
Is there a tool for unroot?
Thanks dawg. Going onto my 5th thunderbolt.
This worked great! I now am running liquid smooth ROM and it is sweet!
Sent from my ThunderBolt! using Tapatalk 2
I am having a problem when i get to the revolutionary pop up screen says waiting for device..._rawadb_handle_msg: unknown command 69766564 am i doing something wrong???
Not sure what that means :confused:
If restarting revolutionary from the support_files folder doesn't help, try re-downloading and re-running the tool
I got it fixed amazing what you can do once you disable your fire wall
Hello all I keep getting this error any suggestions?
Thanks
Welcome Tom!
Do you have the fastboot drivers installed? [Y/N] y
-Waiting for device...
* daemon not running. starting it now *
ADB server didn't ACK
* failed to start daemon *
error: cannot connect to daemon
-Found!
-Getting root with fre3vo, thanks TeamWin!
I HATE that error. Restarting the computer usually fixes it.
Sent from my iPad (the one with no name :P ) using Tapatalk
If you flash .19, you will still have the s-off hboot, so you would just need to flash recovery then su.zip.
The only people that need to root on .19 are people that rooted the old methods (not revolutionary) and people who never rooted before
Sent from my ADR6400L using Tapatalk 2
Reactions: redcat22
When I first read your post I thought it said boot into recovery but I just read it and you said flash recovery. So I won't have to re-root buy I'll lose Clockwork after flashing .19?
Right. Clockwork will be replaced with stock when you flash .19, so you will have to reflash it.
Reactions: redcat22
For linux users, *hopefully* coming soon:
"The device is using! Please stop using the device and try again." When I attempt to install the fastboot drivers. I've restarted my phone and checked for any running sync type programs on both the phone and pc. I feel like an idiot, what am I doing wrong?
Also, this is my first attempt at rooting my device since Droid 1 back when it first came out, and that phone was cake to root, so I'd say that I'm at a beginner level in this area.
Unplug phone and reboot computer then try to install and after it is installed replug in phone
Sent from my mobile look-at device
tejashviyadav
