tried to root, stuck at screen with red triangle, HELP ASAP!!
dw3bb10
47
Im freaking out...but I believe its because I didnt flash a ROM:
Ok, so I ran the auto root, and Im stuck at a screen that I believe came up because I didnt flash a custom rom, it shows the red triangle and "!".....i pressed volume up and power to enter recovery, do i
1. reboot system now
2. apply sdcard: update.zip
3. wipe data/factory reset
4. wipe cache partition
please, help asap!
also, in yellow at the bottom it says:
E: cant open /cache/recovery/command
and, my command prompt says:
"the phone could not be found or was not ready. ADB and Fastboot report it as "daemon" instead of the expected 'recovery'. Make sure ADB debugging is turned on and the phone is in the correct mode."
That's the stock recovery screen, which root method did you use.
Also, power off your phone, turn it on by hold volume down and the power button until the screen powers up, tell me the hboot version and if it says s-on or s-off.
i rebooted the phone, and i seem to be running android 2.1 now! :(
my hboot is 2.02 and it says s-on
im going to RRU back for now. Do i just run that file and it will update my phone? anything to worry about during this process?
timhamel850
