Unfortunately, TouchWiz Home Has stopped.
Mine started doing this the past couple of days too - Galaxy 6s. I just installed Whatsapp a day or so ago. I disabled gestures and cleared the cache, but not the data.
Thank you so much for that fix. this error froze my phone. it froze my phones time which means my alarm clock did not go off this morning. My child was almost late for school and I was late for work. I thought it was a device space issue but did not work when I made more space. This has worked. Thank you.:D
Mine started after a facebook update. reinstalled facebook and it continued. Did not delete messenger though. Seems this 4 Steps accept for messenger has worked for me.
Yeah that update might have been the problem for me. I deleted facebook and messenger about 2 hours ago, works fine for now, no TouchWiz error.
Welcome to Android Central!
Have you tried going in to your settings, application manager, all apps, scroll down to TouchWiz Hone, and clearing the data? this will reset your home screen but it will also reset the app and may fix the issue for you.
I don't sseem to have TouchWiz on my LG G4
It works. Thanks.
this worked for me. .. Go to settings/ my device. Untick motions/gestures. It's ok to keep air gestures enabled. After weeks of searching complicated means of fixing the problem i can't believe how simple this fix was.
what if i am using samsung galaxy j2, where is "motion/gestures"?
Please help me???
Dave
(email address removed by Moderator)
Mod Note, please do not post your email address on this public forum
hey thank you for this 1 year ago info,, my A5 got the same problem this morning then i google and i found this thread ,, thank youuuu so much..
hi,i use a samsung galaxy s7edge,i tried every step u mentioned above,it still won't fix "touchwiz isn't responding" on my phone.
It started all of a sudden with lags,and it showed up the message "touch wiz isn't responding", please help me out.
Thank you in advance.
This error has just started with me this morning, out of the blue. Cannot access the Application Manager because getting Settings had stopped errors too. Attempted to boot into Safe Mode, but the volume down method did not work. Went to the Bootloader, and cleared the partition cache, with no changes.
Trying to avoid a factory reset, but starting to feel that may be the only option...
Do you also have a Tab 2, or some other device?
Oops, sorry, now that I'm on my computer, I see this is a G Tab 2 thread...my search omitted that information when I specifically searched for Galaxy S7 Edge.
For the record, I did manage to get into the Safe Mode, and the tips did not work for the GS7E. After an hour of messing around, I just did a factory wipe, and it's working now. *sigh*
uOttawaGrad_22
