*UPDATE 3: FIX+NOTE!! New Bug after HTC EVO 3D august/26 update!
Re: UPDATE: FIX!!! New Bug after HTC EVO 3D august/26 update!
I have multiple account calendars on my google calendar, but since the update, only entries on my main account calendar show. I have the other accounts entered, checked as active, and only new entries on the other accounts show. None of the other entries do. Anyone else have this prob?
On a previous post i made of this new update, somebody posted there having problems with the HTC GPS widget not being able to turn on or off the gps. So I
tried it myself and found that their is a bug, and in my case trying to turn on or off made Sense force close.
**A simple work around is to use the stock Android power control widget or switch it from the notification bar in the Quick Settings
UPDATE(FIX) :So I was looking around and found the app for the Sprint corp 4G using App Monster(https://market.android.com/details?id=de.android_telefonie.appmanager&feature=search_result) and uninstalled to see if it would fix the issue and did a reboot and everything worked again!!!! The GPS widget and mobile internet widget are working for me!!! Looks like that corp 4g widget was causing problems.... For now everything is working great, no damage happened.
***OF COURSE DO IT AT OWN DISCRETION. I'M NOT RESPONSIBLE FOR ANY DAMAGE THAT HAPPENS. DO NOT BLAME ME IF IT DOESN'T WORK.***
SUGGESTION: You can use App Monster to backup that app just in case something happens and wish to reinstall it.
UPDATE #2: ok so after I uninstalled the Sprint corp 4G app/widget and everything was working great I decide to reinstall it again to see if the issue came again....
After reinstalling it everything was good!!!!
Looks like there's a problem installing it, and MAYBE that's why not everybody is having the problem.
-->Edit: Added Market Link to AppMonster
*UPDATE #3 -> NOTE: so I just turned off my 3VO(with Fast Boot unchecked), left it off for a few minutes and once I turned it on the GPS and mobile internet widget bug was back!!!! Just to let everybody know.
Sent from my HTC EVO 3D!!!
Just in case, I updated the post.
Re: *UPDATE 3: FIX+NOTE!! New Bug after HTC EVO 3D august/26 upda
I am having the same issue. Every time I try to turn the GPS on or off it resets my phone....is there going to be an update???
Best thing you can do is a Factory Reset. That will fix the problem, and believe me it worked!!!
Sent from my HTC EVO 3D using Tapatalk
Prince08900
