USB device not recognized
Worked Like A Charm ! Thanx A Lot Man !!
Try this...it worked for me...Except I started getting this all of the sudden and Every single time I would connect to my PC.
I read this solution on the internet but did not think it would work...but I took 2 minutes and tried it and it worked! give it a try..you only have to lose 2 minutes...
1. hold your phone and look at the micro USB connector on the bottom edge of your Skyrocket
2. you will see a "tongue" inside the USB port.
3. put something "non metalic" (I used a flat wooden toothpick). Gently, lift up the "tongue"..
I used a twirling motion on my toothpick to raise the tongue up a little bit. Don't Go PRYING it up...just be gentle because you don't want to break your toothpick inside the phone or break the Tongue.
I did this and now I do not get the "USB device is not recognized". Give it a try and post here if it worked for you. Spread the word if it does.
Good Luck!
bhai koi btayega Ye USB device not recognized kya hai
Mere mobile computer se connect nhi ho rha hai
What is the USB connector I don't understand
Its working now..hope it will work for long
mobile charging port me jo chip h usse kisi non metal cheez se upar udha do
suuu
