Verizon Data connection issue after root with LG G2VS980
  • Start date Start date
A
AC Question
Rooted LG G2VS980 with Kingo Root and created data connection issue. No 4g connection at all. 3g in and out. Have tried all the data and 3/4g settings changes to no avail
Any help appreciated
Welcome to AC :)
Did you just root the device? Or did you flash a kernel/ROM as well? In any case, it's likely that one of the exploits broke functionality on your device since it was working fine in the past.
OK thanks. I started to try that but looks pretty drawn out and complicated. Can you recommend the best/easiest path to do that.
thanks for your help
Which root method did you use?
Is there a SuperSU app in your app drawer?
Sent from my Galaxy S4 running SlimKat 4.4.4
I used Kingo Root. yes Supersu is installed. I tried using esfile explorer to unroot but it will not work on my phone.
I also tried to unroot using the SUPERSU tool but that doesnt work either
What happens when you click full unroot from within SuperSU?
ok ,SUPERSU would not do it so I downloaded a app called "Universal Unroot" and that did the trick. phone is unrooted but still have the connection issue. BTW I tried another sim card also and no change
it toggles between 1g and 3g but never goes to 4g
Hmm, maybe it's a carrier issue? Do you have access to another phone to test if those are connecting to 4G.
yes I already tested it with another line
At this point I'd suggest just taking it into a carrier store. Tough to help you out with something like this if I can't actually see the device. Hopefully they'd be able to get something worked out :)
