Verizon Droid Cases
If anyone wants a nice pouch case that is promised not to scratch your phone you can always use a sunglass pouch. You can get them at any Sunglass Hut. It works...
I've been looking high and low for alternatives to VZW's case. Almost all cases use a magnet to secure the flap; very few use Velcro.
I did find Nite Ize' medium sized side case that should fit my Droid at Bass Pro Shops online. Haven't checked the nearby store yet. It's a dark brown leather and looks to be a bit nicer looking than the usual black leather suspects.
Nite Ize Genuine Oil Skin Leather Clip Case Sideways
If you want a solid holster case with Velcro check out Marware's C.E.O case for the iPhone 3GS. Fits perfectly on the droid.
Siedio should have there cases and clips ready soon. My guess in the next month we should be seeing many new products for the Droid. I purchased the tour the first day it was out and ended up buying some verizon cases because that was the only ones available. This time I will wait for the good ones to be made.
So I'm guessing most Leather Iphone pouches would work?
Went into BB and almost bought one last night but wasnt sure. I want one with a suade interior to keep the phone unscratched.
I would assume so. I have a bunch more at home that I will double check for you. That Marware one I listed above does indeed have the soft suade interior.
hey baycruiser try the bodyglove shell gives ur droid protection and swivel clip. I had the leather case as well and it sucked...
cases for droid?
Hey all.... I just ordered a rubber case as well as n extra battery for my Droid. Any advice On cases for this. Does It still function as well? Its a snap on silicon case. Thx in advance all.
Just purchased the silicon case as well. I should receive it tomorrow. I'll report back tomorrow.
I just got mine and cant get the front piece to stay/snap on, but otherwise it looks fairly nice.. lol
That's what I thought.
Had some of the same issues with my cases for my old Voyager. But they seem to do the job nonetheless.
I have the VZW rubberized shell/case. It's fine for now, but I think I'll try the Amzer Silicone shell when it's released in mid-December.
vdacau
