Verizon gets marshmallow tomorrow... (Update: It is out now!)
Re: Verizon gets marshmallow tomorrow...
Update went smoothly, however, now my fingerprint scanner doesn't work at all. I'm able to load fingerprints, it just doesn't open with the scanner. It still opens with the unlock pattern. Any ideas?
Found out, with my phone, to use the finger print scanner you just can't lay your finger on the button, you actually have to push it in, as if your turning your phone off. It's weird.
I am having same type problem. The fps never coming up only pin. I knew I should have waited. Did you ever get a solution to this problem.
Same problem here too. Would hate to reset the device. Working very smooth otherwise
I had this problem awhile back. Us LG back up, factory reset, and then LG restore
Are those of you having trouble with the fingerprint scanner using a lock widget or just unlocking after the screen times out? After the update my fingerprint scan wouldn't work after using an old lock screen widget but it worked fine after a time out lock or after a double tap lock.
Haven't done the factory reset yet. It's strange. If I lock the phone, then wake it up, the pattern lock comes up. Once in a while I let the phone sit for 1/2 hour or so, then wake it up, and it prompts me to use the fps.
Did LG back up to sd card. When doing the factory reset, should I remove the sd card first, or can I just leave the card in and not worry about losing data on the card?
It gives you the option for the SD card. I left mine in, no problems. When you go to settings to do the backup/reset just don't check the Remove all SD card info.
Samsung Galaxy S7 and Galaxy S7 Edge from Big Red are seeing updates that should improve WiFi connectivity
Figured something out. If I double tap my screen to lock the phone. I have to use the pattern to unlock it. If I push the power button to lock the phone, I have to use the fps. Interesting. Maybe that's the way it's supposed to work.
Good find. Works the same way for me too. Though I don't like it, I'd rather use FP every chance I get and I do like to lock using double tap.
It's always something or the other which happens every time an update rolls out.
Strange, i can unlock mine with either FPS or knock pattern... Makes no difference how i put it to sleep. Same as lolipop.
Battery drains in stand by mode super fast. I lost 16% in 6 hours - phone was sitting on the table all the time and not touched for once.
It used to be 6% in 8hrs so it's a significant hit. Should I wait a few days ?
In my experience, after many updates from previous phones, that is normal. Clearing cache or even doing a factory reset will help with any future problems.
Anybody experiencing huge battery drain due to the display after updating. I used to get decent battery life, but drains super fast after update. All indications are pointing to the screen brightness. I did factory reset after update and have auto brightness on.
I did the first night. Then factory reset and all good now.
That's actually true
Is this something new to Marshmallow? With Lollipop, you just lay your finger on the button.
bassey
