- Feb 6, 2017
- 98,706
- 15,269
- 113
Thank you !
Is this from a file manager you downloaded? Can you find this files on the device?
Thank you !
Thank you !
If you activate this file manager can you remove the virus?Yep,it's the file manager and offcource i can find it.
Ok, can you explain little more how you mentioned you identified it but cant remove it?I don't know where's located.
It's hiding in android system (the process).
To me it doesn't sound like anything got installed to remotely go into your phone, if someone had remote access they would lock you out and take what they want from your device
Do you have any weird activity going on with your device? Or any account hacked?Yep,exactly the virus gives full control of the phone.
Do you gave any weird activity going on with your device? Or any account hacked?
I have to agree with b.diddySomeone just control my phone remotely (my phone settings has changing without i even touch the phone,battery drain so quicky that usual,my apps has closing unexpectedly,also got alerts from gmail that someone has been logged in my acc from Windows machine etc etc.
Its just i dont see enough evidence here thats says yes you been hacked remotely or virus , you would have far worse things happening, how long this been happening?It's so hard to proof that im infected with it since any av program does not detect it.
Someone just has been changed the settings of the brightness,the sound.Opened even browser with random music, start procesess like gallery and camera.
When i play games and just browse over the internet.Both just close without any error.
I must say that is real thing happening and im not paranoid.
And yes i'm using linux and my phone only.
You can try here or xda forums for your deviceThanks for your patience and time guys.
How i can reinstall the firmware?
I accidentally installed an firewall (No root firewall).
When i opened asked me to allow/block an incoming connection from an ip and the process was android system.
Offcource i blocked it.
Then it asked me to allow/block and the process was the same.
When i blocked them it also asked me to do than again,but the ip was the same.
And then i installed an app (Network connections).
I opened it and saw 5 or more connections that was behind proxy (i traced them and they were from hotspot shield vpn .... )
So i searched in internet with the symptoms of my phone and found that the virus is Remote administration tool.
