Voltage control settings
I have been experimenting the last few days, and I've settled on a setup that's stable and working for me, not sure about EXACT battery life yet, haven't wiped bstats yet since I settled on this setup. But with moderate to heavy usage of dolphin browser, scoremobile, and scoremobile fc, espn scoreboard, texting, some calls and voice mails, little gps here and there, I was getting anywhere from 13-18 hours with this setup over three day trial... See if that improves after clearing stats. Not a whole lot different from my other test or my baseline, but heres what I'm running now...
1000: -100
800: -100
600: -100
400: -125
200: -125
100: -175
Still sio scheduler, and 1000 limit!
Can someone assist me with the screen capture...whats the procedure to capture screens. Thanks
If your on com ROM and already flashed the screen capture package then just simply hold down the back button and press the power button after you should hear a capture sound as well.
What is the patch I flashed 1.2 patch already but it still is not working. Any further directions. THANKS
I use browser, messaging, Facebook, twitter etc... all day
Sent from my SCH-I500 using Tapatalk
That's odd that they don't show up on your display for battery consumption.
I eventually gave up on the OTB kernel, it just didn't play nice for me
I also gave up on OTB when I kept getting SOD, even with nothing lowered more than 75mv. I'm back on ComaVolt and happy.
I've been running these for two days and it's run perfectly:
sio
1200: -25
1120: -25
1000: -50
800: -50
400: -75
200: -75
100: -75
Went with these settings with the OTB and had the best battery day that I can remember. First day of batery stats wipe so it will only get better.
Moderate use today. 25 % left after 15 hours of use.......first time in forever I haven't had to charge at some point during the day. That's all I've ever wanted.
I LOVE that you guys get better results on my settings than I did lol
I didn't get any SODs I just got awful battery life even after 4-5 days of it set that way
Here's another screen shot showing everything I have been using.... really not sure why the last one didn;t have everything show up
6+ hours, 76% remaining.... on pace for 24+ hours
have you tried OTB v1.3? Its been amazing for me
I'm trying it now actually, well, 1.4 we'll see how it works out, kept the same settings as before except I moved 100mHz down to -100 instead of -75 since CPU Spy was telling me my phone spends a lot of time basically asleep and it can handle the -100 just fine
1200mhz: 1300-25=1275mV
1120mhv: 1300-25=1275mV
1000mhv: 1275-25=1250mV
900mhv: 1275-25=1225mV
800mhv: 1200-50=1150mV
600mhv: 1175-50=1125mV
400mhv: 1050-75=975mV
200mhv: 950-75=875mV
100mhv: 950-75=875mV
used this settings for 3 days and got good battery results. unplugged battery at 7am and after 40 hours of minor usage (facebook, texting, calls and browsing) still have 20%.
do you have all those checked off in the states pull down is well? also what is ur limit clock to and also scheduler. ty
I also have one more question that I feel like an a55 for asking..... what do the numbers signify exactly? Does -25 mean a 25% reduction in power consumption? I have a lot of thoughts swimming around in my head I am not sure how to articulate so if anyone can please explain to me (in simple terms) what these numbers mean I'd appreciate it.
It means a 25 millivolt reduction in the power supplied to the cpu
Sent from my KB Fassy via Tapatalk
Reactions: sushiguy732
SO I just flashed v1.3 and I think it reset all of my volatage settings. It put me back to a limiter or 1000mhz and unchecked 900mhz and 600mhz states and took away all of my undervolting.
I think I am gonna run a limiter of 1200Mhz at copy AmanteNJ's voltages at
Except I am gonna keep 900 and 600 unchecked since they were already that way, possibly for a reason? Wish me luck!:D
I am running some battery tests now and then I am going to try these setting when my battery runs out. I am also on 1.3 which I love!....
Forget about this post... I am an idiot! I didn't realize that The Indian was using AmanteNJ settings to begin with....
steveianson
