Volume Button problems...
noone22
13
Hey guys,
My volume button (to increase the volume) is stuck like inside of the phone (idk if I'm explaining it right). Like when I was to turn the volume up, I press the button, and it turns it all the way up. When I click the the down button, the volume goes down, but goes back up.
Any way I can fix the button?
Thanks for the help! :)
Hey guys,
ouch. if its under guarantee then get it fixed properly (dont try n fix it yourself)
good luck man
global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess ;)
should be unless youve rooted it mate :)
nah, haven't rooted it, got it of a plan so I'm not sure.. should I try like get it out using a pin or something?
you could try yeah, just dont open the phone up lol :)
sounds like a spring or something has gone though.
let us know how it goes :)
Should have 1 year warranty from factory even if you bought it off contract. I would contact your provider.
Sent from my SCH-I535 using Android Central Forums
hmm.. how do I vacuum it?
just stick the vacuum hose against the button, block up any gaps and suck any crap out of it lol.
youd be surprised how many things thats fixed :)
Just got my DNA, had issues with the first one within 2 weeks and had to swap it for a new one. Now I'm having volume control issues with the second one, it turns down on itss own. The ringer volume and the in call volume, it has a mind if its own. I guess I'll be taking it back for a third DNA,,,,,, :(
time to seek professional help mate.
try vacuum cleaning the button 1st (dont ask lol)
My Samsung Galaxy Core Prime phone is stuck in safe mode. I've uninstalled apps, factory reset. Still in safe mode. Google then says it could have to do with my volume down button not functioning. I checked and no my volume down button doesn't work. Can you help me please?
AciDDreamZ
