VPN Access Not working with 4g WiFi Hot Spot
p08757
** Superhero **
Oct 22, 2009
1,546
103
Does anyone use the built in WiFi Hot Spot feature to access work with VPN? If so, does it work for you after the 4G upgrade?
Internet works fine, but connections to my VPN server at work failes every time now.
Just want to know if its just me or somethng broke with the upgrade.
Thanks in advance!
This *may* have been a Verizon problem in my area. I got it to work late this afternoon.
I think there might be some problem with the configuration and you will need to configure the settings again... Setting VPN on iPhone 4 is easy and i get step by step guide from Bestvpnservice
I remember reading somewhere that there was an issue with VPN connections over LTE due to an issue with WAN IP configuration. I can't say for certain though and for all I know, it may have been fixed since.
Reactions: p08757
Everything has been fine for the past two days. Keeping my fingers crossed that this doesn't happen too often, especially when I really need it. I'm going to blame this one on something with VZW.
rajaryson24
