Wet-Install Screen Protectors - How Do They Feel?
The fit is perfect. It's cut to size perfectly. One of the cutouts were just off a tad. Nothing noticeable during use.
You also said not very clear right? Well check back in a few if you get the chance to let us know if edges remain in place. Thanks!
It's not clear because it's the matte / anti-glare / anti-fingerprint model. I imagine their clear version is just that -- clear. All of the edges appear to be down still.
That's the key.. along with unhampered screen sensitivity. My screen kind of sucks even bare. I often have to tap a thing twice for it to read.
Yeah - some good points above - You'd think that the manufacturers of the N7 protectors would have learned something from the S7.
So, if I have it right, no one has found a clear, full coverage, film protector for the N7 that "works". And that more than one person agrees to that fact.
Sucks.
Will take time I guess.
I have a crappy protector on now, and have one on the way that has not been reported in this thread. I'll report back when I get it.
Well my yootech wet screen protector was fine, but the edges keep peeling and not where the case is hitting it, its along the sides... it now has dust under it and wont stay down... im afraid to go naked... has anyone tried Clear Coat??
So, just checking in...
Is there a single film protector that more than one person can verify actually works? No bubbles, edges stay down, can be used with a case. I don't think I am asking for too much!
I've got the two crappiest protectors on the market now. Need something good.
Bestskinsever worked great for the s7 edge. They have it on preorder atm.
I have the IQ Shield LIQuid Shield Full Body Skin on mine. Having issues with the screen protector. One of the edges is peeling off. But everything else looks good. Might try a different brand for the screen protector or order another one and try it again.
I received the Illumi AquaShield wet-apply film protector yesterday. Will install tomorrow and report back.
Interestingly, this brand actually has good ratings. Most other brands - even the good brands - have terrible reviews.
Hoping this does the trick.
I've got a TPU film protector on now from Pleson. The issue with bubbles resolved itself over the past few days. But still, the orange-peel surface looks terrible, since it's TPU it's tacky and virtually unusable with the stylus, and the edges won't stay down. I've discarded the XtremeGuard protectors already. They covered 80% of the screen, making it impossible to write or swipe over the edges of the protector.
I finally gave up and got the two-piece unicorn beetle pro. Holds down the screen protector and makes me feel a little better about when my toddler is running around the house with my phone.
How does the Skinomi do with your spigen cast?
I had the same issue as you with the IQ shield the sides lift every few days and if I try to fix them to much the corners start to come up which is not fun.
I had a skinomi on a tablet so I know they feel different how does the pen write on it with it being mushy?
You'll have to excuse my handwriting. It's also mushy enough to where you can see your writing on the screen protector, which self heals itself from smaller imprints like these.
As much as I like matte screen protectors, it seems like every good one for the Note 7 will be a wet install one like this. Therefore, it'll have to be thicker and has a mushy feeling to it. Because of this, I'll probably switch to a formed, tempered glass one eventually. I don't think we'll be seeing basic non-wet matte screen protectors for a long time, if ever.
http://i.imgur.com/Moh9Mvq.jpg
Bestskinsever has a matte screen protector version......
A full coverage, non-wet install version?
It is wet install, sorry.
Here is what they say:
About Our Matte Screen Film
Matte film provides low shine with a unique look that nearly eliminates smudges and screen glare. The trade off, however, is a reduction of the sharpness of the screen. See our blog post on Matte vs. Glossy Screen Protectors for more details.
Their blog : Best Skins Ever Screen Protectors: Matte vs. Glossy
http://www.bestskinsever.com/blog/best-skins-ever-screen-protectors-matte-vs-glossy/
Their Matte Case Fit to screen is : Our Case Fit screen option is designed slightly smaller than the standard screen version to allow clearance between the screen Skin and a hard case that overlaps the screen glass.
Here is a YouTube video for Matte done on the S4. It is full body coverage.
http://youtu.be/_jo3KqoNSp0
In the process of installing the Skinomi matte full coverage screen protector. It's going surprisingly well, though the curved portions take some extra time so that they stay down (which they are). My fear, which came true, was that the screen protector is one of those "mushy" ones that can easily be indented with something like your fingernail. Though, I think the few markings that I already [accidentally] put onto it are healing themselves.
Here are a few photos. Will let it cure for a while before putting my CandyShell Grip onto it.
http://i.imgur.com/BMbdWAF.jpg
http://i.imgur.com/vAKvS34.jpg
http://i.imgur.com/D1080ci.jpg
http://i.imgur.com/bRWFOwi.jpg
http://i.imgur.com/xZlsIx2.jpg
There's now some slight peeling in the corners and a few other areas. Skinomi said that you can carefully lift portions so that you can try and re-seat everything. A heat gun / blow dryer can also be used. I'll be trying this sometime.
It seems like everyone raves about his screen protector but after a few days comes back to say edges peel up especially if using a case. Maybe I'm just a skeptic.
Anybody have any luck with the Zagg they put on in mall kiosk? I can't do it myself and vzw zagg doesn't work.
I had a Zagg HD put on at a mall kiosk and it was great with no bubbles and edge to edge coverage except for one side where it is lifting. My guess it as not perfectly centered on the phone. Since they had a warranty, I am going to go back and get a new one. They also have a policy where I can upgrade to the glass when it comes out and I pay the difference.
The feel is good despite the orange peel feel. The pen has a difference but it is fine for me.
Not encouraging though. I'm hoping for success stories more than good warranty although it is great that they will try again.
Somyatandans
