What are your favorite cases for the Galaxy S6?
Yes, the UAG feels great in the hand. It adds hardly any bulk at all the the phone.
I'm a little skeptical how good it would protect the phone from a drop though. :(
My UAG saved me several times when I dropped my S4 onto concrete (more than once) and on hardwood floors. The last time I dropped it, it landed face down and survived. In fact it never had a scratch on it from any of my drops. First thing I did with my S6 was put a UAG case on it.
Too bad these phones don't come in the following colors ... it would be cool in and of itself ... and I'm sure the cases to go with them would be cool too - assuming you're into the whole colored phone thing ...
RUBY RED:
PASSION PINK:
LIME GREEN:
GRAPE APE:
ORANGE CRUSH:
Been using the Seidio Spring Clip Holster for the last 24 hours. This isn't a case exactly, which is why I was interested. This holster provides protection when the phone isn't in use, and when the phone is needed it is super easy to release it from the holster. Kind of the best of both worlds, protection for a naked phone. Now if you don't like things attached to your belt (or pocket) then this isn't for you. Of course there is zero protection when out of the holster, but I have found anytime I have dropped a phone it is almost always when putting in my pocket or taking it out. So I'm hoping the easy access of the holster solves that. Also, I find myself being very careful walking around corners, getting in / out of the car, etc...because the back of the phone is exposed. I'll get used to it though. If holsters are your thing or you want your phone naked with some protection, I'd recommend this no problem.
I got my S6 yesterday. While I was till in the store I installed a Seidio Dilex case. I like this case a lot. I seems like it will provide a lot of protection, but isn't really much bulkier that a Seidio Surface, which I used for years on my previous phones.
The fit is perfect, and it has a nice kick stand too!
RUBY RED:
http://i1130.photobucket.com/albums/m528/wiggum333/GS6_RubyRed.jpg
PASSION PINK:
http://i1130.photobucket.com/albums/m528/wiggum333/GS6_PassionPink.jpg
LIME GREEN:
http://i1130.photobucket.com/albums/m528/wiggum333/GS6_LimeGreen.jpg
GRAPE APE:
http://i1130.photobucket.com/albums/m528/wiggum333/GS6_GrapeApe.jpg
ORANGE CRUSH:
http://i1130.photobucket.com/albums/m528/wiggum333/GS6_OrangeCrush.jpg
I remember from my RIM days that there was a company that you sent your smartphone to and they would replace the shell of the Blackberry with a custom color replacing all the logos making it look like it came from the factory.
Any issues with scuffing from the spring loaded clip or the holster itself?
jpc007, what happened to you? I saw banned on you name and no action on the boards.:'(
Now, I have this Pimpin neon green TYLT Vu wireless charger to go with all my other Pimpin green accessories. :p
The white UAG looks cleaner but liking the Trident case. How does the Trident compare to, say a Commuter or Defender? Does it work with a wireless charger?
I went right back to my Commuter after having my phone in the Trident for 5 minutes. The Trident is an OK case with real soft silicone liner, port covers, lanyard attachment and even a grill over the speaker to keep out debris. I don't know what it is but I just don't like it. :(
The camera cutout is pretty severe and the front display lip looks a little shallow. How does it compare pricewise?
Got it from Amazon direct and I believe it was north of $30. This is one I might be returning.
The front display lip is not shallow all, it's rather beefy.
Does anybody have a Spiegen Neo Hybrid in a clear case for the Samsung Galaxy S6 ?
I have a PureGear I bought at Best Buy the buttons stick out too far. You are always hitting them by axident.
Hoping the Speigen Neo hybrid don't have the buttons stickin out as far.
I do not want a real thick case and one that you can run over with a car and it don't have a scratch like the otterbox.
That's more case then I would ever want.
I'd rather lose my phone then to have a Otterbox style case.
Thanks !
RUBY RED:
PASSION PINK:
LIME GREEN:
GRAPE APE:
ORANGE CRUSH:
ColorWare Custom iPhone 6
I think this the website. They don't do the GS6 unfortunately.
Been using this for 1 day now:
Amazon.com: Galaxy S6 Case, Spigen® [PREMIUM BUMPER] Galaxy S6 Case Bumper **NEW** [Neo Hybrid EX] [Satin Silver] Premium Bumper Case - [1 Back Protector Included] Hard Polycarbonate Frames Slim Dual Layer Protective Bumper Case for Galaxy S6 (2015)
If you truly want to show off the premium build of the GS6 (and still have some protection from a case), this is the way to go. I have a Ringke FUSION Crystal View (clear back) aslo, and it still doesn't show the back very well. The Ringke is a good case, but you won't find a "clear back" case that shows off the build better than "no back".
Now, I will say, the Spigen doesn't add much grip to the phone, where the Ringke did add some grip. So far though, I think the Spigen will be my daily driver.
I was considering that but felt an exposed back was asking for damage. That said how is it going with yours so far?
Just ordered a new Spigen Neo Hybrid to go with my new S6 128GB Gold Platinum that will be here next week. I like the diamond cut edges and the aluminum frame whichis much nicer than the plastic version.
Are you using a glass screen protector? The display lip doesn't look deep enough? Are there port covers for the USB and headphone jack?
mrtalha
