What are your favorite cases for the LG G4?
Ok so I just got this case for my phone last week //images.tapatalk-cdn.com/15/07/01/3f33c4dfa906996ed7e96b59cdccb9a6.jpgoff of eBay for a few bucks. . Came with a few accessories! Anyone know what that fish looking thing is for? I'll take a pic with the case in the phone later when I can. Looks pretty nice and has that rubbery feel so it won't slide around.
Sent from my VS986 using Tapatalk
Hehehe I got the same in black....excellent fit and perfect grip...slim and light. It matches perfectly with the back gold buttons
Posted via my LG G4
The camera app gives you more control than most, though. Unless you look deeper, it’s as simple as anything. And with the ‘Auto’ HDR mode set as standard, there’s really little need to do anything but press the shutter button. thats why i just love it... and i think this is the first cellphone working like DSLR
Posted via my LG G4
Wow that's awesome! I love this case! Love the texture and it does fit perfect. For just a couple bucks can't go wrong!
Yeap indeed great value for money...$3
Posted via my LG G4
Here are pics of the Supcase. It's a bit on the rugged side and offers water resistance (not waterproof). It looks like a cross between the Otterbox Defender and Spigen Slim Armor. Even though it's not slim, I don't consider it to be bulky and it looks like it will offer some solid drop protection.
I removed the section of the built-in screen protector over the display since I have a screen protector installed. There's still a portion of the protector around the front camera and earpiece area. It also has plastic covers over the back camera, laser auto-focus, and led flash. A thin layer of mesh also covers the mics and IR blaster. The earpiece and back speaker are covered too, but audio doesn't appear to be affected. The port covers work fine for my plastic-backed G4, but there have been some Amazon reviewers stating their port covers don't fully close with the leather-backed G4. Additionally, the rear buttons are covered, but remain easy to press.
Here's an imgur link to the Supcase album in case I add more pics not posted here:
Excellent pictures and review of the case! I'm currently torn between the Supcase and the Spigen Neo Hybrid.
I like that the Supcase covers the front with a screen protector and has swappable backs, but I'm a bit concerned about the plastic coverings for the rear camera/AF/flash...are they very easily removable?
Additionally, compared to the Neo Hybrid, is the Supcase that much more bulky in terms of pocket-ability and daily use?
I'm pretty sure the plastic coverings would be easy to remove. Whenever I clean them, there's a bit of flex with the adhesive it uses so you should have no problem taking them off. With regards to the Neo Hybrid, the Supcase is still easily pocket-able. There is a noticeable difference in bulk, but not too much.
If you need a bit more protection then I'd definitely go with the Supcase. Compared to most cases which have a big opening on the back, I like how Supcase cut out openings for the camera, flash, and IR blaster. The built-in screen protector it had seemed to be of decent quality, but I'm not sure how durable it would be. At least you have the option to remove it later on down the road if it gets too scratched.
I have the Spigen Neo Hybrid and I love it... I actually like it more than just using the black leather back (in Canada we got both the leather and plastic backs in black), as it's easier to hold on to the phone. I'm not using a screen protector, so I can't speak to that. The Neo Hybrid is very easy to slip into my jeans pocket, is very classy looking, and fairly easy (maybe 7/10?) to put on / take off of the phone.
Is that made of pure silicone or tpu? I want one made of silicone because they are a lot easier to take off.
I have had both the Otterbox Commuter and the Spigen Neo Hybrid Case. There are two types of thought when it comes to cases. Either you don't care about bulkiness and just want protection or you want some protection but want it to fit well in your pocket. If you want the most protection hands down the Otterbox is the best case for you. If you want it to fit better in your pocket and some protection then the Spigen case. So depending on what you're looking for you cannot go wrong with either case!
Here is my new case. Another pink one. But I like this one cause it kinda looks like a leather back. And the cheap bumper I got off eBay. Love these new cases. The bumper is a bit silly with the color on the back. But I'm waiting for my pink leather back to come in to use it. And what's that little black flap doing? Pics taken on my bfs iPhone.
tjp5p8l1xf
