Whatever happened to the MultiStar Good Lock module?
FWIW... I just sideloaded MultiStar and it also showed up within GoodLock (albeit with the "unplugged" moniker.)
Reactions: mustang7757
Update is out for One UI 6. But it's still not working for the beta I guess. Still saying unplugged in the Good Lock app though.
Are you on the beta?
I am on the beta, and I didn't have it listed at first. Then I sideloaded it (to make it appear within Good Lock), but even then I could only update it "manually" via the Galaxy Store.
Ok... Mines is saying unplugged in the Good Lock app. What device you on? I have the galaxy fold 5. How do I side load it?
Click on 'More' then Go to Store and it should allow you to update the app. If not, you may have to wait for the release for your model.
To sideload, search for MultiStar on apkmirror.com and download and install the APK file.
Reactions: Marlo859
I've already updated it... It says One UI 6 support. But it's still saying unplugged in the good lock app. And if I search for multistar in the galaxy store it doesn't show up. I got it by Google searching it and it sends me to the galaxy store to download it.
Can you post the link for the apk you used?
If you tap it (as you normally would to open it), does it, in fact, open?
No... It's doesn't do anything when I tap it .
Edit: It's working now
BrüZZi
