- Feb 6, 2017
- 99,106
- 15,813
- 113
check in advance setting if direct shade enabled if that's what your looking for
check in advance setting if direct share enabled if that's what your looking for
Yes I have a US carrier version so the software is slightly different in some areas than yours. I'm running out of suggestions here. I still would do a system cache wipe. At this point nothing to lose and no harm in doing so.Yes, tried with the Spen, and it works as it should.
You've got a note 9, haven't you?
It's there for me. Odd issue. Hope you find the culprit!Firefox has also lost the action to share to clipboard.
So, it's definitely a 'share' issue.
Just did a system cache clean, and it still doesn't show up. So darn strange ¯\_(ツ)_/¯
Try restarting your phone , sometimes clears small glitches
Sorry didn't realize you did that already
Try clearing. Cache in both play stores in app setting
Yep, cleared cache and data settings for both, and still no go. Weird eh![]()
You went into settings, then apps 3 dots show system apps clear cache in clipboard and force stop ?
It is weird
And try reset apps also in apps 3 dots
Worth a try those 2 steps and not just clear cache force close the app clipboard
Yeah, did all that too ¯\_(ツ)_/¯
one other thing I just noticed when I try to share to my clipboard I long pressed it and cam up app info goggle drive , maybe clear cache their and force close see what happens
I don't have google drive installed.
Did u delete it ?
If so download it and see
It worked after I installed Google drive - bastards aligning it with that app!!!![]()
