Where is this T-Mobile 5.1?
I went ahead and did the update via force closing Google Framework, etc. Worked fine. It's only been about ten hours, but so far have not noticed a difference. I even went ahead and did a factory reset. I'm on T Mobile, and received version M.
I did the same thing, but my phone I'd noticeably smoother and the overview no longer lags. Trusted face is working now and the toggles are a great addition.
What exactly did you close to make this happen? Thanks
Settings, apps, all apps, Google services framework, clear data, clear cache, and force stop_ then settings, about phone, and update phone. Location history may request to be turned back on!
I got my update today. Either they finally released the floodgates, or posting on this forum yesterday did the trick.
Upgrade Method: Normal – used “check for update”
Phone Model: XT1103
Purchased from: Amazon.com
Wireless Carrier: T-Mobile
5.1 Build: LMY47M
I hadn't been notified but I hit "check for update" and got it this time. Yay!
Nothing yet....grrrrrr....
Try with that one does suggested about the Google cache clear. Not sure if it was just coincidence but I certainly get the update immediately after doing it a couple of times. Good luck
I must say that my download speeds are much faster at home on cellular. Several download tests show this. Not sure if picking up the extra band or whatever it is helped. Definitely noticeably faster though. All around.
I try this one,doesn't do nothing I think I just need wait.
Yep..finally. After trick ....
Did the Google cache clear trick and got the update. Thanks everyone. Downloading now.:)
Hopluikla
