Where's the FM radio?
So there is no way to get it to work on T Mob version, correct?
This can't be an AT&T issue because my AT&T locked Nokia Lumia 1520 Windows Phone has the radio and it works perfectly although I don't see the radio on my G3. Why would they disable it from the G3 and not the Lumia? This isn't making any sense....
^^^Perhaps Nokia would not allow it?
I have unlocked phone and FM simply dissapeared. Operator is portugal MEO
It defenetly not a operator problem.
Did somebody find a way to get it back?
If you haven't been using the app, it may have been removed from the app tray by Smart Clean....look in Update Centre > App Updates, and scroll to the bottom.
Also, welcome to AC and the G3 forum.☺
Thanks so much for ur response! I did found the app in update centre)
^^^It doesn't use much battery, either.
this is a feature that has made me change plans, I switched from samsung since galaxy s4 because of it,...to HTC!
now I am thinking about switching to LG G3, what do you think about the g3? I found out that there are some problems by fixing signals, switching data to wireless and battery,...true?thanks
If the carriers are asking the manufacturers to supply modified phones, the manufacturers could always say 'No, we'll supply them the way we want them to be or not at all. Take it or leave it.' The carriers need the phones, so they'd have to take it.
exactly what Apple does.. No Bloatware period.
It's called 'FM radio'. I looked briefly in the Play Store, also tried 'LG G3 FM radio', but found nothing. I'm not sure that it would be a normal type of app....more LG's way of accessing the FM radio built into the phone.
This is what the icon looks like:
Can someone on Verizon grab some headphones, and install the app and see if it works? Gettin a G3 this week.
Verizon G3 owner here. I installed an FM app from the store, it said no FM radio hardware found.
^^^Certain apps are sometimes missing and that's one of them. Ask your carrier about it.
I now have an HTC One M9 through Verizon, and am also without radio. I downloaded Next radio, and even installed the .apk for the FM Tuner, but I get an error about the tuner.
BrüZZi
