Whitestone Dome for the Ultra has Blue Light Cut ?
If you take it off still issue? Just curious if anything else .
Unfortunately, I'll have to wait until I get something else in, to try it without any glass on here. But that's also why I took a picture at the same time with my N10+, in the same conditions.
Understand but definitely test it out without any protector before I put nother one .
so, while the WSD screen protector doesn't add a blue hue to the screen, with their blue light filter. the camera glass protector they offer, does. when you take a picture with the flash, it creates a blue fog in the upper left hand corner.
Are we certain that the camera glass has a blue light filter? I thought the purpose of a blue light filter was to remove blue light not add it. I think any glass over the camera lens will reflect off the flash and cause issues. I would opt for one with cutouts over every lens or none at all.
Sorry, I didn't mean to say the camera glass has a blue light filter, but that the glass is reflecting the flash and causing a blue haze in pictures.
That makes more sense. I typically avoid flash pictures unless absolutely necessary. My daughter always a flash.
Got my WSD installed today and it came out pretty much perfect.
My question is how much curing should I do? Did two 15 seconds and two 60 seconds.
How much more curing should I do? Can you over cure this thing?
Guess I'll wait at least 24 hours before trying on a case.
If its tight fit case wait 24 hours
5 times
60 seconds top/middle/bottom
I did 10 minutes on top, middle, and bottom.
I'm ready to remove the WSD glass because of the smearing and fingerprints. I simply can't clean it of the smearing, let alone keep it clean. I'm using alcohol wipes, lint free paper towels, microcloths, it doesn't matter. When I use the spen, all of my writing shows up in the fingerprints when the display is off. I don't remember ever having this problem before.
Mama Mia
