Whitestone Dome for the Ultra has Blue Light Cut ?
The lady at Best But puts the wsd on.
She makes it look like a piece of cake.
My buddy did it..
It was tough for him.
Did your WSD go on smooth without any bubbles or any problems at all?
Any excess glue running down the sides? I'm losing sleep thinking about installing this thing and I've done 3-4 of them in the past.
There shouldn't be any bubbles unless you have dust. A little glue on the sides is not a problem because there is a wipe down step before final curing
Not quite. When it was time to take off the heavy plastic bar that helps the glue spread, I kinda slid it a second before picking it up (I misjudge the weight of it) and the whole protector slid! This is the step right before you cure it. I tried wiping with the alcohol thing but that also made the protector slide around. I didnt want to cure it with the adhesive all over the bottom and top so I took it out the tray, wiped the bottom and sides as best I could, then cured it as directed.
After I finished I used a regular sized alcohol wipe, the ones that look like baby wipes, and kinda buffed the spots of adhesive off. Somehow, it's clear as glass without bubbles, smudges, or dust.
I am debating on installing the screen protector before I even boot it up. I can't remember if I did it that way with my N10+. Not sure if it would cause any issues??
That's how I did it. I always install it before even booting up. It would suck one day if I installed it and it was a dead phone.
Thats what I ended up doing. I'm still backing up my N10+, so I am going to setup my N20U tomorrow. just watching YT and reading the forums until I fall asleep.
Just make sure you install the absorbsion pads once you put the top cover on. That will help with excess glue not running off of the sides.
Did you rescan your fingers after installing the Dome?
I put on the glass before ever turning on the phone. I redid the scanner because it was so finicky. But now it's working great. It may have been glitchy because it was still updating/restoring the phone in the background.
Mine is on, my OCD sees that it is slightly off center by the tiniest bit. About 5 minutes after curing the glass for 10 minutes, I put it in a case (Caseology Skyfall) and the one corner (because it's slightly off center) lifted. I took it out of the case, pushed the corner down, and let it sit out over night, and now it's fine! I put it back in the case, and been using it in the case all day and it seems to be a perfect fit. just the tiniest bit of gap all the way around the screen protector and the case edges. If it drops and lands on a corner, it will definitely pop one of those corners off again. I really wish Supcase would bring the Style cases to the Note20/Ultra.
I usually use the UV light 60 seconds top/middle/bottom 5 times before putting a case on . Wonder how it manage to go off center a little .
I don't put a case on till the next day after install to give it time to set.
ayham
