Whitestone Dome for the Ultra has Blue Light Cut ?
BBB is 100% useless for almost everything.
They've helped me also. Got me out of my AT&T contract because AT&T coverage map said I had good coverage but I didn't. They kept telling me the map was accurate and wouldn't do anything for me. Typed a complaint on BBB website and AT&T canceled my contract and we to a different carrier.
Hey has anyone here tried both the AVFilm and Whitestone tempered glass screen protectors? Can you please tell me how they compare?
I went with the AVFilm because it was cheaper and I saw a review saying it was compatible with my case (whereas I couldn't find any compatibility confirmation for the Whitestone). Unfortunately, despite following the instructions to the letter I still had major issues. When I pulled the pin away the screen protector got stuck on the application tray, forcing me to push it past the tray so it can fall down onto the screen. Unfortunately this happened and caused bubbles on both applications. I also heard the AVFilm adhesive is runnier, which I can believe since it dripped down the side of my phone. Even worse, despite putting the speaker grill sticker on correctly the adhesive got inside both times. Fortunately it didn't harden when cured though, it just turned into a glob that I was able to scrape out with a corner of a piece of paper.
AVFilm gave me a full refund and now I'm looking at Whitestone, which I assume has the same case compatibility because it's not like two screen protectors for the same phone can differ that much in dimensions right? Thankfully Whitestone's installation seems a bit easier and less likely for things to go wrong if you follow the instructions!
I gave in and pulled the trigger on WSD. Use code LABORDAY25 on their site to get it down to $48.75. Really hope I can get it to install properly to make the fps work.
I wish I had waited. I did get the camera protector free, so I guess I can't complain.
What made you not want to pre-order from WSD? They were on sale for $56 after promo code. And it was 2 in a box. Thats $28 each. I had the camera glass protector too, but it caused a glare from the flash on all the pictures I tested with in the dark. So, I returned it. Im waiting on a Caseology camera protector now.
Yup i guess it is with 3 glass protectors , but still regular price is 84.00 with special deal 79.00 still way to pricey.
You can get that one for $64 with discount code NEWPRODUCT20. Hope they release it for the Note 20 Ultra within a couple of days, that way I can return the one I just ordered and get that instead. After two botched AmFilm installation processes, even though I'm positive it wasn't my fault, I am scared of that step with the pin. Don't mind paying more for an extra tempered glass screen protector and to eliminate that step entirely.
I just simply waited. I didn't pull the trigger when I should have. Has anyone had any luck with the camera protectors from WSD?
There's a thread on the camera glass and peoples experiences with a camera glass protector. Unfortunately, WSD, dropped the ball and it doesn't live up to the main screen protector experiences.
That makes me sad. Well, I guess I'll have to get a new one. The Caseology one is the best?
I got the Caseology one yesterday and so far everything has been perfect. Pictures are crisp & clear and no problems with flash washout.
The Caseology one looks fantastic on my black N20U. Not sure how it would look on the bronze or white phones.
I have the black too. I guess that's what I'll be getting.
Yea, they are of very nice quality. Just be careful when peeling that thick white backer off not to peel the clear guide handles off instead.
My clear handles peeled off while trying to remove the backer and I had to install mine without the guide handles. Just a heads up.
Thanks!
miyonfaga
