Whitestone Dome for the Ultra has Blue Light Cut ?
How is everyone's WSD holding up? Any scratches, peeling up, cracks or any damage at all?
Mine has only been of a few days and the only problem I have are a lot of fingerprints.
Nope good here, Same as my Note10 Plus since preorder day not one single scratch nor no lifting on it at all.
Mine is doing great, even after a few issues with my cases, it seemed to have worked itself out, and no lifting on the corners now! 🙂 there is one slight "spider bubble" in the corner just left of my front camera, but its only noticeable when the screen is off, and it doesn't really interfere with anything, so I am okay with it. Not complaints, just mentioning it.
Mine is great but I am having difficulty finding cases that are WSD friendly. What cases are people using with their WSD. We should keep a list. So far, the Spigen Tough Armor is a perfect fit. I also have the Neo Hybrid and Rugged Armor and both are snug on the top and bottom edges of the glass.
The Poetic Revolution and Supcase UB Pro cover some of the top of the glass an press on it, making it not very compatible as it will ruin the installation. Bummer.
Good point , my Spigen thin Q with bottom not great fit .
The Otterbox Symmetry (black), Samsung Rugged and Gear4 Battersea are WSD friendly.
The UAG Monarch case is just too close at the top and top corners for me. My glass also might be on a little high though.
I believe there is a Post where people have commented what cases they are using with the WSD. I have the I-Blason Ares, its similar to the Supcase UB Pro, and yes, it just covers the top and bottom also, but it still covers and doesn't seem to be too big of an issue.
With that said, I also have the Caseology Skyfall, with the WSD. It initially was good, and then I had to take it off to get to my SIM card. And then when I put it back on, it was pushing one of my corners up, but thay corner was also slightly off center to begin with, but for some reason, ever since its been fine. No lifting or anything. But it does sit very flush with the WSD at the top and bottom. If I drop it, it'll likely pop a corner up wherever it lands. But as long as it keeps the actual screen safe, I'm fine with it. Thats what I got it for.
You must of put it a bit to high cause all my UAG Cases are compitable with it and the Monarch as well , not just me most people has mentioned that it's compatible, so you probably right your glass wasnt aligned correctly just saying.
How can you line it higher-up?
If you don't drop in right can be off by a bit or also as i seen if push it in to much will go under the plastic dome tray that it's in.
Damm , once you move that top tang the screen drops and glue starts spreading no need to touch any further , once that glue spreads then UV light few times and out the tray UV light few more times , they have point triangle corners in the tray to prevent movement.
If its tight fit case wait 24 hours
5 times
60 seconds top/middle/bottom
Do you use a rugged case? I have the amfilm uv gel one coming. I have the otterbox defender pro and a poetic revolution case coming and I'm getting nervous with some of these comments about lifting lol
Hi, I don't
But let it cure good before installing a tight fit case like a day
Hi, I don't
I hate to say this but let's hope he gets lucky, I've heard Otterbox Defender isn't compatible with the Glass screen protectors and if Poetic Revolution is Unicorn Beetle will lift screen protector.
Then try 2 days curing and see what happens
Not good news... lol At least amazon allows returns on it if it doesn't go well.
UB Pro and others like it are very dependent on how well you install the WSD. Generally speaking, it should be fine because the WSD will likely sit just under the frame of the UB Pro, it may cause a few sma bubbles, but it shouldn't fully lift it, if installed well.
Flykxd133
