Why a non-expandable memory
Probably because the price is so low that they want people to spend the extra money to get the 128 gig version instead of just buying a 3rd party sd card
Design requires trade-offs. They cut corners to get the base price as low as they can.
En lo que a mi respecta, prefiero el dual sim a la capacidad de expandir la capacidad, yo necesito mas posibilidades de comunicaciòn que expandir la memoria, para es suficiente la memoria del one plus 5
I agree with you, I think it is enough 64, if for any this is not enough then you should consider buying the 128 GB, but the option to expand I think it is unnecessary
What is enough now might not be so later, and since there is a 128 GB version available for a price that it's not that much higher, I think that is the safest bet.
Yeah, I cant see myself filling the 64Gb, yet alone the 128gb
It is tough right now, I agree, but who knows about the not so distant future. There was a time when 1TB disks were even huge for backup servers, and now it is quite OK (or even small) if you have lots of movies stored in your computer.
They were able to put in the option on the Huawei p10 to use either a 2nd Sim or an SD card. With just 64gb of internal memory though, I find I rarely even use my SD card. Just get external backup, whether via cloud or hdd
64 gb is ok but 128 is great you can copy photos and videos to your pc or an ext hdd if you fill the storage
Apparently they didn't use a Micro SD because it didn't guaranteed the performance they were going for with UFS 2:X (it's the same thing Xiaomi said about their Mi Flagships lacking this characteristic their redmis do have)
This is it. People love their car similes, so I'll say it's like putting a roof box on a Lotus Elise... Or your own quick car of choice.
Yeah. You get more storage, but at a huge performance cost.
It's also why all the manufacturers cut them for a generation... Crappy performance. They came back because people complained... Although that's more understandable if the max or even base storage is 32GB.
sukorenojaya
