Why does my talk to text and typing stop working mid sentence when another message comes thru
No I keep my wifi calling off because it's unreliable in my opinion. Verizon is my carrier
Funny thing is my previous phone a note 9, one of the best ever made, was experiencing a lag in sending texts and emails. No one could figure out the issue. There's was nothing else wrong with the phone. It was a great phone. But because sending emails and texts is of the most importance for my job I decided to bite the bullet and by, for the first time ever, a brand new good phone, instead of a used liked my note 9 or second hand which most my others were. And I'm having even worse issues. I have researched over there last couple days thru Android Central and read other similar issues with others. Yesterday I did change my text app to the highly recommended chomp messages and there is no lag in taking my typing. It catches it from first word instead of second. The words are more accurate and I'm spending less time fixing them. Today at some point I'll know whether talk to text cuts off while another function is tripped.
And to add,... Yesterday two phone calls I had the other caller could not hear me. One was Bluetooth one was not. These were before messaging switch, not that it should make a difference regarding calls. Also, I installed avast just to insure no malware/spyware... Nope was already using Kaspersky.
May I ask a question, I turn off background data on a lot of apps like games and things that should not be a problem for the functionality of the phone. What shirts of things should I not do that to. Also I read about missing bands in 5g .. is this true? That's screwy. Also read about a certain number that should be within the phone that gives it the correct communication with your carrier in order for it to receive and server messages correctly and efficiently. Can't remember what it was called... Do you know what this is or how to scare that all the right detrimental components and setting are correct for property functionality. It's love to be able to bring my phone to an informed specialist to check it all. But send not many know what they are really doing anymore
How old is your sim card ?
I just bought the phone I went from a 4G note 9 to a 5G note 20 so I went and got a 5G SIM card so it's new
Ok good
You might want to try a factory reset because it be too many steps to have you try this and that to see if they can work .
You disabled apps background usage how?
Individually thru each app
Setting
Apps
Choose the app
Storage clear cache
Mobile
Turn off background data
Most of these games etc do not need to run in the background using data and monitoring me. It should not hundred the functionality of the phone and long as in not turning off the important detrimental apps
Correct
Setting
Apps
Choose the app
Storage clear cache
Mobile
Correct
Correct
I do not use Android auto. I notice it's uninstallable. I turned it's background data off. It's this ok?
And what is " my phone companion"? And all these AR apps? I have Bixby set to not be instigated by side keys. Why do we have to have it and other things on our phones? Seems really stupid
AA yes can disable background if dont use , my companion i believe its when you continue work on computer or tablet . AR emoji you referring to?
Each manufacturer like to implement their own features and Samsung is heavy on features .
RangelS25
