Why doesn't my LG G3 seem to connect to wifi?
  • Start date Start date
A
AC Question
lG G3 Isn't connecting to wifi no matter what
Going on Data hardly works, either. Super slow loading times.
Anyways, my phone will try to connect to the wifi network perpetually. Load them, rather. I tried turning my bluetooth on and off, I restarted it, shut it down, pulled out the battery, pulled out the SD card, cleaned out some apps and media to clear up more space(had like 5 gb left anyways) and then I performed a factory reset. Absolutely nothing.... literally. There is no perpetual loading, there are no networks showing up, and I can't search for or add any.
It was working perfectly fine up until this afternoon, when it suddenly just stopped loading our wifi network randomly. I've been at it all day with zero luck.
Re: lG G3 Isn't connecting to wifi no matter what
Sounds like a hardware problem to me if even a factory reset doesn't bring it back. Might be your radios or something else is dead. Time for a repair shop... to at least have a look at it.
whiteraice
