Why is it the first time my Nexus 6 rings, the volume is very low but during the second ring the volume increases?
2 seconds delay on sound Nexus6
Hi everybody!Purchased the google nexus 6 32GB (white) last Friday and got it yesterday and have been using it for almost 24 hours! I have noticed this delay and its about 2 seconds. The sound delay is everywhere. If you press play on a youtube video there will be a 2 second delay until the sound of the video reaches the speakers. Same thing goes when somebody is calling you or messaging. The volume will start low at the top speaker and after 2 seconds will work properly. Also while having a phone call if you press the speaker button, it will take 2 seconds until the speakers are activated. I don't know if its a bug for the 5.1.1 or if its some phones but i personally called Google today and reported the problem. Would like to know if there is a fix or if its a device problem.
Nexus 6 ascending/increasing ring: Fixed.
NEXUS 6 ASCENDING/INCREASING RING: FIXED. Yeeeeeeeeah!!!
I *had* the same problem since the first day of use of my N6 until... yesterday! The upgrade from Lollipop to Marshmallow didn't fix it, as I hoped. The only things I did yesterday are the following:
1. I uninstalled Google Launcher directly from the Google Play Store
2. I uninstalled Google directly from the Google Play Store
TIP: Search "Google Now" on the Play Store. Two results appear in the following screen. Tap the first result and uninstall it. Go back, tap the second one and uninstall it as well.
Then I reinstalled both. After that, I had to rebuild my home screen manually, my folders and so on. A lil disappointing, but it took just 10 minutes (and a couple of blasphemies... helpful, as usual). You can take a screenshot of your home screen (powerbutton+volumedown), first. This will help you rebuild everything.
3. I changed the ring from "default" to... the same ring but with its name, choosing it from the stock helper app "Media Storage". I did the same with Google Messenger and Whatsapp.
4. I installed the official LinkedIn app.
Magically, the increasing ring has disappeared. The funny thing is that I was trying to fix a different problem! :-)
I imagine that both LinkedIn and Whatsapp doesn't matter...! I'm just telling you *all* the things I did.
Let me know if it works, please. If it does, I'll disseminate this information all over the web, since a lot of people have this problem which, as I've understood, must be a software bug and not a hardware lock or a hardware bug as I red in certain forums.
Byebye,
Andrea - Milan, Italy
Re: The first time my Nexus 6 rings, the volume is very low. During the second ring the volume incre
The first time my Nexus 6 rings, the volume is is very, very low. During the second ring, the volume starts to increase and is at the set level by the time the second ring comes in.
Does anyone have a fix for this?
Thanks,
Joe
Thanks
AjdinFaz
