Why is there no Aokp rom for the sprint samsung galaxy S3?
New update to DeviantXone once again today. Highly recommend it.
I'll switch over once the hybrid is back
Got a few reboots with Liquid today, after using the flash of the camera, and then got a random reboot a few mins ago
Clean flash
I won't even go into how much trouble i had installing my apps earlier. Lets just say rom toolbox didn't backup my data, and only my apk files. And I couldn't restore those apk files using the app, had to do it manually using es file explorer
Clean flash
Try Carbon, best you will ever use
Can I flash the bms 4/22/13 d2spr kernel on the LiquidSmooth 2.2?
Keep getting random reboots which is very annoying
And for the second day in a row... another update to Deviant Xone. Minor fixes and add ons.
Another one? Lemme check
Yup. Sunday's update was called "B1" and yesterday's update was called B2. I'm telling you man, switch to this ROM! The dev puts in a lot of work and is very dedicated. ROM is smooth as hell. No hiccups for me. Plus the update with hybrid settings (P.A.) should be here within a week.
I'm going to switch to over, it's just a matter of when
Well, looks like I won't be flashing deviant at all, hybrid settings have been canceled, so I see no reason to switch to that rom over Liquid
Devs actual words: "Hybrid Settings is being cancelled, BUT I'm still adding custom UIs. Stock, Phablet and Tablet UIs are being added still, BUT it won't be Paranoid Android's Hybrid Settings. I'll be adding back Xposed Settings again, but updating it of course.... This will allow the per-app DPI functions that some of you may want, which offers more options anyways lol..."
Don't like xposed interface, only wanted to use pa DPI changer
Clean flash
Still having issues with Liquid Smooth 2.2 Official? I'm still running a Liquid Smooth build from back in March. It's been running mostly great. Just thought I'd check if there was an update and if its worth updating or not. With 300+ apps and the pain of reinstating all of my settings if I update to LiquidSmooth 2.2, I'm skeptical lol. I'll just stick to my old build until I get your (Soundtrack to Chaos) official thumps up.
Go with Deviant Xone, wayyyy better!!
mistan
