Wi-Fi Problems: Android 4.1.2 [Galaxy Fame]
AndroidProblems
4
I recently purchased a Samsung Galaxy Fame, pre-loaded with Android 4.1.2, from India during my most recent visit there. However, upon arriving I've realized that it will not connect with my home Wi-Fi. The Wi-Fi is not faulty as it runs approx. 40 Mbps on my laptop (not connected to modem), however, the phone fails to connect to it. I've tried turning on the Wi-Fi, but it is stuck on "Turning Wi-Fi on..."
When I go directly to the pre-installed Internet browser it reads what would seem to be the default message for no internet, "No signal found for mobile networks"
I would greatly, greatly appreciate your help as returning this product (if even possible) would mean sending it overseas (I'm in Canada), which would be costly. :(
If the problem is connecting to WIFI, The first step would be to test it with another wifi connection also verify other devices being abel to connect to your WIFI. If the problem persist and you are not able to connect to any WIFI networks anywhere, This would be a device issue, You can try a factory reset but that may not make a differece. Since WIFI is not over the cellular network and your home wifi is functioning fine and other devices are able to connect that only leaves the device as the problem.
Thank you for your reply, even though it may not exactly be relieving :( , it tells me where I maybe should begin to look.
I did do a reset yesterday.
Im sorry. I see this issue alot! I work for the network team with sprint and we have Trouble tickets created everyday for the same issue you are having.
That actually means you have no cellular data service. Was a working SIM card in the phone at the time?
The router I'm using currently is a Cisco DPC3825, that probably isn't of relevance. but it is a modem that doubles as a router and was supplied to me by my ISP. It may not be that common, I've also got a D-Link (fairly common router, forget the exact name), that hasn't been tried yet.
Source with examples please?
My HTC One X Wifi worked fine. When it upgraded to JB, suddenly it wouldn't even see many routers - including one of the two at my home. Later that phone was replaced with another that was initially loaded with JB. Same problems. A third phone had the same problem. I've been wandering around the boards looking for a solution. I have found none, but I have found many postings with similar problems on many different phones from various manufacturers. Thus my conclusion that the problem is with JB.
This is the short version. If you want more details, find my threads here about it.
My best educated guess is that the JB wifi is fussier about connections and/or timing than ICS and many other devices. Unnecessarily so considering how many routers worked before, but do not now. Judging by the wifi complaints about 4.2 and 4.3, the bug/feature/whatever has not yet been corrected.
I have not noted specifis router problems, but there are a number of bug reports and posts on dual band issues. Seems 4.2 and 4.3 are exhibiting issues trying to connect to 5GHz but connect to 2.4GHz just fine. If I turn my devices to connect on 5GHz I either fail to connect or quickly drop the connection.
I had the exact same issue with my Fame. To solve it the only thing that i did was to temporarily delete the WEP password from my ISP provided modem-router and then my phone would let me conecct to the network, then load the password back on and thats it. I hope you can fix it !
kenster23
