Wifi Tether Problems on BAMF Sense 3.0 GB RC4
nolescorp
5
First - thank you to this great site and to all who contribute. I have been lurking here since the TB was announced(sorry) but never had anything to say that wasn't already covered in a thread. I finally rooted when fed-up with the reboots and GPS issues - and I am in love with the TB all over again. This ROM is awesome!
I have scoured the forums looking for others with recent issues with Wifi Tether, TBolts, and BAMF Sense 3.0 GB RC4.
My recent issue is with Wifi Tether 3.1Beta. I can not get any devices to connect, or get beyond "obtaining IP Address." Here is what I have tried so far:
Routing fix enabled within program
Flashed old wifi fix
Shut off home router
Installed various versions of wifi tether (2.07, 2.08, 1.something) - none work.
Tried Barnacle and another wifi tether program - still no luck.
Tried connecting two different home laptops and my wifi xoom - no luck.
Started on MR2 radio. Flashed MR2.5. Still no luck.
Tried with and without encryption
Tried different device profiles, setup methods, and channels - no luck.
Also, I tried uninstalling the program, but it messed up the phone. Only the notification bar appeared after uninstalling - no icons. Phone would ring but I couldn't answer. Reset/Battery Pull didn't work, so I reflashed the ROM and all went back to normal. Same thing happened again when I tried uninstalling. Old versions uninstalled fine.
Any advice? Thanks to all in advance.
Try a different kernel, might work. Wipe cache and dalvik in cwm, and flash a leankernel by imoseyon or a dreamkernel by zeronehl.
Reactions: nolescorp
Update - was able to get wireless tether 2.08 to work on leankernel - not blazing fast (only 3g here) but working. Don't know why the newer versions of wifi-tether don't work. Thanks for your help!
Reactions: musculature
rabcd
