WiFi will not turn on, no networks listed.
dlmurphy
7
My WiFi connection worked yesterday, now it doesn't.
When you try to turn it on the button stays gray and the other side says "turning on"....but never does.
Bluetooth works fine.
Galaxy Note 10.1 2014 Ed.
SM-P600
Android Ver. 5.1.1
Kernel ver. 3.4.39-6161737 dpi@SWHD8915 #1
Please Help!!
I factory reset the tablet...and still no WiFi....noticed there is no IP address listed for device.
Wifi will not turn on after factory reset indicates it's dead. Repair is impossible as it has many components. Your only option is looking for another used mainboard or a tablet with broken LCD.
Wifi and bluetooth have separate components so they are not related and rarely fail at the same time.
Thank you for the info, was afraid it was "dead".
Where are some places to possibly purchase a mainboard???
Thanks again for your help!!
liliin
