Will there be available tempered glass for S7 edge soon?
  • Start date Start date
If you buy a Zagg film protector, they will credit you the difference when their glass protector comes out.
Posted via the Android Central App on the edge
I don't believe the Zagg glass for the S7 edge will ever come to market. :'( Just what I think.
I never got that far.. I just mailed it back @ my cost yesterday. thing was flimsy and broke on the corner when making adjustments. it has a think adhesive strips on the sides and it makes that glass on glass crunch. Its "suppose" to be corning gorilla glass, if it is I think it might be first gen or something. Seeing how it broke so easily I would not trust it even if it was on looking and working great.
People need to save their time and money and get get a good case, good film protector and INSURANCE.. If your planing on having this phone for 2 years get it. I wish I didnt have to learn the hard way
I would get the Samsung protection plan from them directly. Better than some of the Asurion/Carrier options.
Plenty are and will be available but all will fail. :'(
It's just the nature of the beast.
As far as I can tell most fail due to cases pressing against the sides where they adhere. Spigen guarantees their protective film won't have this issue with their cases, although they do not produce a glass protector. If they can solve the issue with the film though, solving the issue with the glass protectors should be doable. I'm still curious as to why they don't do a glass one though.
If you plan on using this as protection on screen. You will break it if you plan using case.
Crissy Doug
