[WIP][KERNEL][ROM] Wildfire S Virgin Mobile USA
Followed instructions and everything works as described above.
Question: What is the best version of "QPST Configuration to use? Found a few versions out there. Might you include this program here (or a link to it)?
Thank you!
Newer ones are usually better. But don't really matter. The nv read only error is our radio still being s-on. But i cant link or post here against forum rules.
Sent from my HTC_A510c using Tapatalk
Reactions: Tymnus
That's in there. As for everything else, I've dedicated my time to ics. I want to be the first ics booting wildfire s cdma
Reactions: FromUndaChz
Excellent, let us know how it goes!
Some devs on XDA developers forums have something coming along nicely... pretty sure they have screens of it booting but it's extremely limited at this point - give it a look.
OMG! I NEED HELP in changing the PRL for faster Internet and better signal! it seems really difficult compared to s-offing and rooting the virgin mobile HTC wildfire S, which I did easily. Can you please make a video ? I don't understand the directions and I don't want to risk breaking my phone. Also can you please include the QPST file and PRL file. There's so many of them on google that I don't know which to download. It would be easier for me that way. Also, can you make new directions IN DETAIL like really IN DETAIL and email it to me? Please include all files for the PRL hack for better data speeds.
Root Explorer, goto the system/apps dir and delete what you want, reboot to recovery and clear delvik cache.
This said be careful what you delete you need some of these apps, so you may want to make a backup before playing.
OMG! I NEED HELP in changing the PRL for faster Internet and better signal! it seems really difficult compared to s-offing and rooting the virgin mobile HTC wildfire S, which I did easily. Can you please make a video ? I don't understand the directions and I don't want to risk breaking my phone. Also can you please include the QPST file and PRL file. There's so many of them on google that I don't know which to download. It would be easier for me that way. Also, can you make new directions IN DETAIL like really IN DETAIL and email it to me? Please include all files for the PRL hack for better data speeds. :confused:
I am posting this on behalf of Simon because it fixes issues in both hboot and recovery and it give you HTC developer support. It is important to follow these steps exactly and in order to avoid any headaches or complications. THIS IS ONLY FOR VIRGIN MOBILE USA WILDFIRE S USERS, IF ANY ONE ELSE TRIES THIS NEITHER ME NOR SIMON ARE RESPONSIBLE FOR ANY DAMAGE DONE TO YOUR PHONE!!!!!here it goes.
1. Download both of these files and put them in the same location as the adb file.
misc.img
flash_image
2 Open the terminal on your computer and enter the following
a. adb push flash_image /data/local/
b. adb shell
c. su
d. chmod 755 /data/local/flash_image
e. /data/local/flash_image /sdcard/misc.img
After this you should get a message that looks like this if you followed these directions correctly
(usage: /data/local/flash_image partition.img )
That is it your phone should not reset or anything and you will notice any obvious changes up front but it is recommended by Simon that you do this for it gives your phone HTC developer support. BUT ONLY IF YOU HAVE A VIRGIN MOBILE USA WILDFIRE S.
This next step is important to do after fixing the misc.img. This is the official bootloader update for the Virgin Mobile USA Wildfire S, it will give you the latest HBoot update and enable you to unlock your bootloader on HTC's website. After you download the file move it to the root of your SD CARD and boot into HBoot mode and select yes to update bootloader. ONLY FLASH THIS IF YOU HAVE A VIRGIN MOBILE USA WILDFIRE S, SIMON AND ARE ARE NOT RESPONSIBLE IF YOU DAMAGE YOUR PHONE. After that run got to the HTC Dev link and select unlock bootloader and follow the directions. That said here is the link posted at the request of Simon.
https://docs.google.com/open?id=0B_5eOCW-U-iXOTU4NDRmZWItOWU4Yy00ZGFkLTkxZDEtYmRhYzUwOWZiMGU4
And here is the HTC Dev site, go to the unlock bootloader option, register for an account and unlock your bootloader by following their directions
http://www.htcdev.com
All testing was done by team marvelUSc, and there is a new kernel that will be coming up soon after more testing.
Oh and nvm, I changed the PRL easily. I took my sweet time but I did it. The only thing is that my internet is not going any faster than what I had before. It seems about the same. What is the difference between the 61007 and 60681 prl files? and how can i update to the lastest Sprint prl.
misc.img
flash_image
b. adb shell
c. su
That misc image fix simmon nor you knew about or figured it out. So it would be nice to be credited for fixing it to begin with. In which the misc image was corrupted upon s-off via the old process. The for reference here is my gtalk log over it.
Code:
	6 minutes
10:11 PM
me: dd if=/dev/block/mtd0 of=/sdcard/misc-stock.img bs=4096
you need busybox installed
10:12 PM
simonsimons34: from android or recovery
me: either or
10:13 PM
simonsimons34: ok ill do it from android
/dev/block/mtd0: cannot open for read: No such file or directory
10:14 PM
me: um hold on
try dd if=/proc/mtd0 of=/sdcard/misc-stock.img bs=4096
I can't remember wtf it is on nand
10:16 PM
simonsimons34: no go
same error
10:19 PM
me: cat /dev/mtd/mtd0 > /sdcard/misc.img
try that
10:20 PM
simonsimons34: something happened
10:21 PM
got it
10:22 PM
E: Missing bitmap icon_installing
in recovery
me: what is that for
10:23 PM
simonsimons34: Mkm had that error i got her into recovery but she got that error and it rebooted
me: are you talking to her on gtalk?
10:24 PM
simonsimons34: yep
6 minutes
10:30 PM
simonsimons34: got the img how do i decompile
10:31 PM
me: upload it and give it to me
tell her i never got a invite from her
simonsimons34: Lol ok.
18 minutes
10:50 PM
me: as in I didn't get the talk invite
simonsimons34: i know i told her bout it
invite her
jjpolkri@gmail.com
10:51 PM
me: did you upload that dump ?
simonsimons34: still uploading lol
me: how big is it
10:52 PM
simonsimons34: 1mb lol. uploading at 35 bites per second
10:54 PM
me: also i think she has a bad download or something with that recovery
simonsimons34: weve tried multiple
10:57 PM
http://www.mediafire.com/?ljnfv9esxs7tge3
11:01 PM
thats it
5 minutes
11:06 PM
me: uh there is no cid in this
11:07 PM
simonsimons34: Well, what can i do about it lol
me: fastboot oem boot
go to h-boot
got to fastboot mode and try that above
11:08 PM
simonsimons34: hang on i need the fastboot file
11:11 PM
u know where i can get it other than sdk
11:16 PM
me: try this
http://forum.xda-developers.com/attachment.php?attachmentid=588859&d=1304719623
simonsimons34: thanks
11:18 PM
wont detect my device
11:19 PM
me: you have to be in fastboot mode
simonsimons34: Thats a given
me: You guys aren't s-off fully and I believe you are partially bricked
simonsimons34: huh? me or her
11:20 PM
me: all of you
There should always be a cidnum in the misc-image as ruu's check the misc partition
yours is screwed up and corrupted
unless you uploaded a corrupt one
11:21 PM
simonsimons34: Lol great. Hang on I'm going to loose internet.
11:25 PM
ok i got it. got the output too
OH and mkms recovery worked for gsm only not cdma?
11:27 PM
super cid....
11:28 PM
me: paste the output
simonsimons34: simon@Aspire-5251:~$ adb reboot bootloader
simon@Aspire-5251:~$ fastboot oem boot
(bootloader) setup_tag addr=0x60000100 cmdline add=0x9D07DEE0
(bootloader) TAG:Ramdisk OK
(bootloader) TAG:smi ok, size = 0
(bootloader) TAG:hwid 0x0
(bootloader) TAG:skuid 0x2D101
(bootloader) TAG:hero panel = 0x3
(bootloader) TAG:engineerid = 0x0
(bootloader) MCP dual-die
(bootloader) TAG:mono-die = 0x0
(bootloader) Device CID is super CID
(bootloader) CID is super CID
(bootloader) Backup CID is empty
(bootloader) setting->cid::11111111
(bootloader) serial number: HT199X001642
(bootloader) commandline from head: no_console_suspend=1 console=null
(bootloader) command line length =536
(bootloader) active commandline: board_marvelc.disable_uart3=0 board_marv
(bootloader) elc.usb_h2w_sw=0 board_marvelc.disable_sdcard=0 diag.enabled
(bootloader) =0 board_marvelc.debug_uart=0 smisize=0 userdata_sel=0 andro
(bootloader) idboot.emmc=false androidboot.pagesize=4096 androidboot.bas
(bootloader) eband=0.94.00.0824 androidboot.cid=11111111 androidboot.batt
(bootloader) _poweron=good_battery androidboot.carrier=ALL androidboot.mi
(bootloader) d=PG76*** androidboot.keycaps=qwerty androidboot.mode=norm
(bootloader) al androidboot.serialno=HT199X001642 androidboot.bootloader=
(bootloader) 1.06.0000 zygote_oneshot=off kmemleak=off no_console_suspend
(bootloader) =1 console=null
(bootloader) aARM_Partion[0].name=misc
(bootloader) aARM_Partion[1].name=recovery
(bootloader) aARM_Partion[2].name=boot
(bootloader) aARM_Partion[3].name=system
(bootloader) aARM_Partion[4].name=cache
(bootloader) aARM_Partion[5].name=userdata
(bootloader) aARM_Partion[6].name=devlog
(bootloader) partition number=7
(bootloader) Valid partition num=7
FAILED (status read failed (Protocol error))
finished. total time: 6.060s
11:29 PM
me: ok wtf is going on here then..............
11:30 PM
you are supercid as it says and is what 11111111 means
how ever that misc image i got is corrupted
Then here is the actual misc image that is correct for virgin mobile http://dl.dropbox.com/u/24065431/misc-stock.img and here is the stock uscc one is here http://dl.dropbox.com/u/18863354/misc-stock.img
I want to thank all of you for your help and hard work making the files, Just a quick note, it would be helpful if you added a "Date" next to the file so users won't keep asking when a new file is released. That way they can see when it's updated.
Hi, I'm attempting to S-Off my HTC Wildfire S. I have followed all the steps and have successfully created the goldcard. But i am to step 13 and i have the files i am told to move, but when i select GOLDCARD (E:) i do not have a ROOT folder. I only have .android_secure and LOST.DIR. Am i missing something? What can i do to solve this?
byronsss
