[WIP][KERNEL][ROM] Wildfire S Virgin Mobile USA
Hello :) I s-off my wildfire rooted installed cement successfully and flashed cm7 alpha its awesome but there are some bugs to it...like wifi hot spot wont work :( is there any updates? I'm still s noob btw thank you and nice work..!! I would love to test your Tom :)
doees your rom support marvelc?
im having a hard time finding a rom that supports my virgin mobile HTC WildFire s marvelc
HTC_A510c
I want to change my S-On to S-Off and I have been stuck on my HBOOT screen where i've got :
Parsing...[PG76DIAG.nbh]
[1] MFG_DIAG
Update is in progress...
Jumping to DIAG...
Clean S58 never appear on my screen..
I 've made twice my 2GB SanDisk a Goldcard with the message from SimpleGoldCard_v1 that my card is succesfully a GoldCard. I have only to things in my Card after making it Gold, PG76DIAG.zip and PG76DIAG.nbh.
If it can help you, i also run S-Off.bat from Wildfire-S_One Click S-off folder and somewher in the begining it says this:
Pushing Diag Files...
failed to copy 'tools\soft\PG7DIAG.nbh' to /sdcard//PG7DIAG.nbh' : Permission denied
failed to copy 'tools\soft\PG7DIAG.zip' to /sdcard//PG7DIAG.zip' : Permission denied
Can you give me an advice about how i'm going to unstuck from here? Any tips?
Sorry about my english.. I 'm not good in writing..
When I'm attempting to do clockworkmod recovery can I put the file on my 4g SD card, or does it have to be a goldcard? If so can I make my 4g a goldcard?
I happen to be an idiot and my 2g goldcard fell out of my shorts.
Reserved for ROM:
CM7 ALPHA
(gnu liscense)
AOSP kernel and CM7 for the Wildfire S CDMA
Copyright (C) 2011 simonsimons34, 2fast4u88
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>
Note: Credit must be given in some way to (simonsimons34 2fast4u88 and bobzhome) for any use of this package other than being used as a rom without published modifications. Im simply protecting our work.
tscmtest.zip
Report anything that doesnt work
Okay guys heres my first ROM, of the series i want to create :)
SS Rom or SimonsStock, Or superstock :) i want you to vote lol.
wipe everything, and install. It will take a long time to flash and boot but do not interupt at all
https://docs.google.com/open?id=0BwZZjRHl9NIJMGI1MTI3ZTEtYTk4YS00NzAwLWE3YjktMWRhZmRkODIzNTA1
Changelog:
Added support in quick settings tab for wifi tether
added root access
added superuser
removed crapware
*left activation app
Zipaligned the ROM for speed
(Bug: when fully charged, notification light may alternate green and red, this isnt really a big problem)
De-odexed the entire ROM (can theme the ROM now, a little bit faster)
Added buisybox and dependencies
added WPA supplicant for ADHOC support
FUTURE:
DSP sound manager
Remove sense
any ideas, post them, ill gladly look into them ;)
when is the next update coming out neo...I'm loving this one..! Nice job.
doesnt works for me
it gets stuck on jumping to diag
i have created goldcard properly
with only two files in it PG76DIAG.nbh and PG76DIAG.zip help me on mail plz or atleast mail me when you solve this prob my htc wfs is gsm unlocked (htc dev)
mhrsolanki2020@gmail.com
doesnt works for me
You have a "GSM" style phone and this foum is for the "CDMA" style phone.
I think the thread you are looking for is thishttp://forums.androidcentral.com/htc-wildfire-s/142359-tool-one-click-perm-root-busybox-installer-cdma-gsm.html
Make sure to read though it to make sure before you make any changes.
Hope this helpes you
Blazer1155
Is there a newer PRL out for Virgin Mobile? Also, I have read of people successfully using the 11115 Sprint PRL-- can anyone confirm this? If so, is it worth doing? My concern would be that it would include towers that Sprint phones roam off of.
Have you heard of prl 60683 its an update after 60631 ima try it out n see what happens
well tested all 3; 60681, 60683, n 11115
Want the results?
:D
The results would be very helpful. Also to prevent roaming set your phone to home only (should already be)
Sent from my HTC_A510c using Tapatalk
I shall post them when I come home from school. Hmmm BTW when is there gonna be a new update for the ssrom? The DSP player don't work on ssrom classic :(
All 3 PRL's were tested in the same location 3 times each n' recorded the best
one of the three test's.
PRL60681:
-Ping:232ms
-Download:1219Kbps
-Upload:952Kbps
PRL60683:
-Ping:198ms
-Download:2178Kbps
Upload:962Kbps
PRL11115(took off the results before snap shot):
-Ping:156ms
-Download:2253Kbps
-Upload:1033Kbps
Note:This tests were made in this location; Anaheim, Ca
and i hope it was helpfull to ya'll :D
PRL60681:
-Ping:232ms
-Download:1219Kbps
-Upload:952Kbps
PRL60683:
-Ping:198ms
-Download:2178Kbps
Upload:962Kbps
-Ping:156ms
-Download:2253Kbps
-Upload:1033Kbps
Great results!
gaganprasad
