Wireless tether....i need help...
BIG CEEZEEWEZZIE
55
I've been trying for 2 days now to get my friends Evo 4g's wireless tether to link and allow access to my laptop.
I have read the previous posts and performed all the functions needed to properly download and run the apk., i even set up the network but no luck. My computer connects but with limited access. Any thoughts???:confused:
Dumb question but...is his phone rooted? What ROM is your friend running?
His rom at first, but did not get any results. Then I did some trolling in this forum and found a blog about wireless tether. I read and downloaded a upgreaded version and still the same results.
I'm not sure what is going on. When I used the wireless app (the one from the sticky) I had a hard time trying to get access. With the built in tether I never noticed it when I used his rom.
I'm on CM7 now and at times with the built in tether I have to wait a few for it to allow access.
I'm not sure either. I think Maybe its because I used to own a hero and hooked up my laptops Internet using the same android wireless tether, so maybe I should delete the wireless profile I created and start fresh. You think that might work.?
It could. I believe I read somewhere that the wireless app would cause some issues if the native tethering app was unlocked as both would try to turn on.
StephanieKc
