Xoom Boot Animation On Droid X
Thanks op dumpped it in the system/media folder easiest process for me now how do I get that bee for the m logo replacement on apex
do you have to extract before putting it in system midia? I've tried flashing the first link and dumping the second neither works for me. Any answers?
First is a flash. Second is a dump. Don't extract. Try placing in data local.
Sent from my DROIDX using Tapatalk
In this section look for my M Logo Replacement post. Its there with a bunch more I put together.
So I finally read what it says when I do it through bootstrap and it is just annoying and saying bad file.not sure what to do
Try and dl the second link. The with root explorer copy from sd card then paste in data local.
very cool but I've been running this boot for close to a month. I thought it has been posted before on here guess not.
Why didn't you share! I had to wait for the system dump to get this together.
Surely it's easier to root explorer and store it in to system/media?
It goes in /Data/Local not /System/Media. If it's not working, make sure you don't have something in both locations, delete any bootanimation files in the /System/Media folder. Also, make sure the file name is bootanimation.zip
It can go in both. It will search data local first. I prefer data local and have the zip to install into there.
Baadshah
