Xoom Boot Animation On Droid X
i tried to load this and i get an (!) with a little android guy next to it.... uuuh i dont think that honeycomb! can i get some help? my aim is fhorn116 i needd help fast!
EDIT: haha i got it it just out me in recovery mode. no worries :L
That im not sure on. Sorry about that. It should be a xml file. I've changed the progress bars using hex colors.
Sent from my DROIDX using Tapatalk
Ok which file controls the progress bar colors? Looking to change that as well. Sorry for.hi jacking the thread.
got the stock android boot logo. do i need to delete something firs? rename the zip? thanks again for all the help
This won't change the m just the animation. Check my m logo replacement for the bee and more.
I'm sorry, it has the android animation where the word android shimmers from the left to the right, I installed right where you suggested, is there something somewhere I need to delete you think? thanks again!
Look in both spots. The old animation may still be there. Also make sure you don't open or extract the zip. Just dl copy and paste.
make sure new file says just bootanimatiom.zip you may have to renamed it and old renamed.
That's a negative :( I appreciate the help. Is it possible that the file you put up to be flashed via recovery is bad? while downloading from Megaupload, i looks strange. Any mirrors that have been created to try a different source? thanks yet again!
Nope file is good. You dl on phone or PC? If phone try PC. I had issues in the past with dl to phone.
Reactions: rh166c
Actually I just got it!!! yay, great job btw. I dont know why but when i used stock android browser to download the progress of the download looked goofy but it would say complete. I used Opera mini and it worked great, 2 different file sizes between the different browsers. ??? ah well I got it!! and great Job again, I appreciate your help fine sir!!!
wobblefix
