y dont i have hboot usb setting on bootloader
Best thing is to start with and read through the instructions in this thread:
http://forum.androidcentral.com/htc...all-about-rooting-htc-shift-faqs-how-tos.html
If you have any issues or questions post here. If the links are not working for you please let me know you have enough posts now you should be able to see and open all the links. Remember we are here to help but I am not always on line I will help when I can but be patient you can figure this out ask your questions but give us time to respond.
nevermond i found one that works so i should just go to the top of ur post and start from scratch and wat recovery do u suggest
The root processes was set up to run on Windows XP or higher. If you can get access to a Windows XP PC this is the only way to root your phone.
how come wen i try to install sdk setup a window pops up ans says
warning java not found and i dwnloaded java alread it says something bout the environment variables wat should i do
tryhomematch
