YourMobileGuru
Formerly VZWRocks
- Feb 25, 2010
- 2,611
- 239
- 0
Let me just say, I completely agree with you Droid800. ICS is by no means a step backwards. A lot of design/navigation alterations made to the OS really help simplify everything. The long-press option was the worst. I always found myself long pressing everywhere and options would come up only every once in a while. Also, you have software menus and the hardware menu button that accomplished the same thing, or for some reason, was split among the other menu options.
The problem here is that many of you are used to the old ways of handling Android. You guys are not thinking through the eyes of someone who's never picked up Android -- or even a smartphone in general. Its about creating an experience that enjoyable and easy to use. In order for that to happen, Google had to make a lot of changes so that information and options were presented right to the user without them having to search through layers upon layers of information. You guys call this a step backwards because -- as I mentioned already -- are used to a certain operation. And many of you have this mentality that something simple makes it 'dumb down'. Android still has all the same features and characteristic we all know and love -- just now its presented a little differently so it could be understood more.
Long pressing on any open part of the home screen has brought up a menu in every Android device have used. How is making it harder to find things like widgets, notification settings, and that kind of thing make it easier. For some people looking in the app drawer for the widgets makes sense. Fair enough allow them to do it that way. but that does not mean that you should make it harder for those of us who use the long press menu.
Other features such as notification settings, creating folders or shortcuts, etc which were on that menu have been either removed (in the case of folders) or moved to an already lengthy (but now admittedly better organized) settings menu which -- now that the menu button has been removed -- isn't necessarily immediately accessible from the home screen unless you have the shortcut there. It's on there by default when you get the phone but a lot of people clear off their home screens when the first get a phone and only add what they want to them, and newbies often accidentally remove icons and widgets from the home screen without intending to.
Simple is not always better, and in this case Google took simple too far.
