Your way to Update...
Well the Butterery Smoothness doesnt feel much different from ICS, But otherwise its going well so far. Im glad i dont have that ugly 4.1 AppDrawer icon. Thanks Touchwiz. For once.
Ok so someone explain to me how I can manually update my Sprint GS3? It's not rooted or custom ROM or whatever any other terminology out there is. It's straight stock, no hacks or weird sh!t. The OTA update hasn't hit at Fort Leonard Wood, MO yet and if there is a safe way to update the file without waiting I'd love to know.
Method 2 should work fine, I'm also not rooted and stock.
- - - Updated - - -
Find an SDcard. I believe the only way to do it is with the SD
Correct, you'll need a external SD card to use method 2.
Yes it's for unrooted devices. Yes it is the official update from Sprint.
Ok I downloaded the zip file to my sd card but there is a lot of files there which file name am I to look for?
Sent from my GT-N8013 using Android Central Forums
Can i download update directly from phone and place on sd card. Then can i update thru stock rocovery?
I used the first post to return to stock using the odin file. Going through the previous updates cycle now, updated me all the way to JELLY BEAN!!!
I just downloaded that file and it took to the L710.13 not jelly bean. How do I make sure it's installed to my sd card?
U have lag time? Of what a half a second? Lol
sent from my UNROOTED but still totally frikkin awesomely customized Galaxy S3
I tried downloading from that link over six times since it was posted and it doesn't work!
Sent from my Innovative Galaxy S3
I am up dated but getting all these error messages, what do I do?
Put the file in your phone, NOT your SD card. After you do that, follow this.....
Shut off phone. Press volume up, power and home button at the same time. As soon as you see a flash, let go of the buttons. This will put you in stock recovery. Using the volume bar to select and power button to activate, select update from external storage. Choose the file you previously put there. Push your power button. Your update will begin.
After downloading the file i went to update from sd card and it saif the file had a fail signature and canceled the update, any tips on how to fix that? I can't wait for OTA i always get mines like 5days out. Screw that noise!
maybe a full second! maybe even 2 seconds! :) But it's still annoying - never had a lag time with my Photon but I'm always waiting for this phone to catch up with me, especially in the text messaging functionality! Annoying!
Is your External sdcard formated to fat32 file system?
The filename should be:
eec955eb4a5b.update_SPH-L710_LI3_to_LJ7.zip
This will be the way to manually update your phone if you are:
Rooted or Unrooted - Stock Rom with all needed bloatware and Stock recovery.
Download the following update zip and place it on your external sd. Go to settings/security and make sure unknown sources is unchecked.
And here it is at last....
UPDATE ZIP IS HERE! And yes it works.
I would like to thank skiskilo and mdmitchell13 for continuing to search for this long after I went to bed.
I get the following error in stock recovery when I try to update via ext storage :
E: failed to mount /sd card (invalid argument)
The . zip file is on my ext card (didn't put in a folder). Any help? Thanks.
S3 on Sprint - 16gb pebble blue + 64
cbbella
