For as long as I can remember, a $10 peel & stick screen protector has went on every new device I owned before leaving its packaging. They're cheap enough if you mess up(which I have countless times and eventually mastered the install process) and are easily removed. The problem is once they're layed down if any, any tiny bit of dust or debris found its way onto the screen during installation you basically need to start over with a new one as removing and re applying usually results in even more dust and debris. With the TBolt being so new I could not find a proper screen protector locally(everyone sells them but not ones that fit the entire display) so I decided to order one online. I have always stayed away from Zagg because they usually have cut outs for things like the light sensor which I hate. Since the Zagg for the TB does not have any cut outs I placed my order. The checkout was a breeze and the status of my order was sent to me every step of the way. Any time my unit moved through the warehouse, I was notified. Being by a Best Buy yesterday I jumped the gun and purchased another Invisible shield instead of waiting for the one to come in the mail. The packaging is superb, including the protector itself, a bottle of solution used to install, an actual little squeegie(as opposed to a little piece of cardboard) and a very nice cleaning cloth. Installation is easier than you'd think because its very forgiving. Should you happen to get any debris, its removable and you can start over with ease. You'll notice at first the protector seem just a hair to small but in reality, its gonna stretch a bit when you start removing air bubbles with the squeegie leaving a perfect fit when finished. All imperfections do work themselves out in about 24 hours and this product is seriously Invisible. Being so happy I email they're CS department. This morning I received an email thanking me, a personal response from the presidents office. They noticed my website in my email signature and offered up a few samples to giveaway to my readers. If anyone is on the fence about buying a Zagg product, you'll be very pleased with your experience.
