So I was rooting my phone using manual root instructions from rootzwiki, and I was on step four
Here you will rename the downgrade RUU as PG05IMG.zip and place it on your SD card by running the following command:
adb push RUU_Mecha_VERIZON_WWE_1.03.605.10_Radio_1.02.00.0103_2r_NV_8k_1.37_9k_1.52_release_165253_signed.zip /sdcard/PG05IMG.zip
Using the adb code to push the RUU and rename it bypasses a lot of problems people have been having. If you're so used to Windows that you insist on dragging and dropping it, be sure to rename the file to PG05IMG.zip BEFORE putting on your sdcard. People have had issues with it not flashing and corrupting the file if they renamed it while it was on the sdcard.
I pushed it in CMD, using adb.. and it went to boot loader screen.. I hit the "bootloader" option, and was supposed to see it update.. but nothing happened...?
It wouldnt let me out, and Im stuck on a screen that reads:
MECHA XD SHIP S-ON
HBOOT-1.04.0000
MICROP-\
RADIO-1.16.00.0223r
eMMc-boot
Feb 23 2011, 20:42:55
SIMLOCK
0: SD FAT32 init OK
Checking key-card...
255: Not key-card!!!
Process done, reboot device?
<Vol Up> Yes
I pressed volume up, NOTHING.
WHAT NOW? Help?
MECHA XD SHIP S-ON
HBOOT-1.04.0000
MICROP-\
RADIO-1.16.00.0223r
eMMc-boot
SIMLOCK
0: SD FAT32 init OK
<Vol Up> Yes
WHAT NOW? Help?
