HogFanatic03
Thanks for this post. I finally achieved root.
did it say all threads completed 0 succeded and 0 failed?
ok my phone wont turn on...its on the Android System Recovery screen and wont let me select anything. what do i do to be able to use my phone again?
Close Odin. Open Odin. Pull your phone battery out and leave it out. Plug the phone into a different port In the back of the computer. Put it in download mode and try again
Sent from my SCH-I500 using Tapatalk
ok im sorry that i am posting a lot i am just a very detailed type of person...
i am looking at the steps in this forum. to just do root what is my first step or what post do i read. im sorry i just dont want to screw my phone up i want to do it right lol thanks for your patience and help
its suppose to read (succeeded 1/failed 0)
either its a bad download or you have a poor USB connection.
try redownloading the file you are trying to flash
did you install drivers?
did you use ports in the back of the computer?
just looking to root , try post #4 of this thread
http://forum.androidcentral.com/ver...-please-read-post-1-before-posting-forum.html
the file has a piece of paper next to it as if the comp doesnt have a program to read it..is it supposed to look like that?
cwm-recovery-ALL-3-30-FIX.tar
ok did you download and install 7zip like i suggested? Winrar will work aswell
yes but it didnt read it...odin just said 1 succeeded 1 failed
do you mind if i screen share with you?
