F34R
F34RTEHDR01D
Gotcha. I've seen the SDK mentioned, and have installed it. I guess I'll start another discussion on how to do it lol. Again, thanks for the help.
Kilo, what app are you using to display the unread # for your gmail?
ugh, I can't find Forte Calendar
That's because it's called Jorte. Just search for that...and leave "calendar" off as well. Just "Jorte" is all you need.
In an unrelated question, I see you use Launcher Pro. I use it as well and my people icon on the dock come up with "could not launch the requested activity" error. Any ideas? I thought that I could also drag my icons into the dock but apparently I can't. Would be neat if I could.
There are a couple ways you can do it. If you installed Launcher Pro it's one of the options for the icons at the bottom, which is what it looks like Kilo did (not sure about ADW cuz I don't use it).
Or, if you don't use a launcher, you can just download Gmail Unread Count from the market and add the widget to your home screen instead of the Gmail App Shortcut. The widget which has a bunch of different icon options will then display the unread gmail count.
My homescreen... Still tweaking
