I was wondering if anybody new of any cases that will fit the Galaxy Nexus with an extended battery? I don't use a case but would like to get one for when I need it. I haven't been able to find anything. Any suggestions would be great. Thanks!
Yes, I have the Incipio on my phone w/extended battery. It's a tight fit but it will cover the phone. There's a slight gap between the two layers of the case, but has no bad effect. The only thing I don't like about this case is that's it's a bit bulky and won't fit in any available holster or side pouch.
I just got a Seidio Surface and holster in the mail. I wanted to like it because it is thinner and had the holster. The case barely closed over the extended battery.. I should say, didn't fully close on bottom, but was latched tightly shut. It worked well in the holster. However, I"m sending it back. I thought I'd like the openings for the volume and power buttons vs the rubber coverings on the Incipio and similar cases. Turns out, I really got used to those outside buttons on the case and didn't like reaching in to push the metal buttons. Also I didn't like the grip/feel of the back of the Seidio, and felt that if I dropped the phone, the 2 layers of the Incipio will give better protection.
So I guess everything has a tradeoff. The Gnex is the longest phone out there and I'm hoping someone will make a side belt case that will fit the phone/Incipio combo.
Just wanted to let you know that the Incipio case does fit in the Seidio Active Holster. I tried it with my friends holster, haven't received mine yet, but it does fit. The Inicipio dual layer case is almost the same size as the Seidio Active case.
tx. good to know. I suspected that since the two dual layer cases look pretty similar in design
