ellesshoo
I added 4 more magnets to the back. Works really well and the pull is very, very, very strong. The only problem I can see is it might pull the battery cover off when you pick up the phone!
Ohio, looks good. I must say the profile cross section of the magnets in the touchstone is somewhat smaller than those magnets. If you have other magnets I'd recommend replacing one in each corner with a smaller diameter magnet or possibly even replace both magnets with smaller ones (should still have more hold than a single 0.25" diameter magnet). If you really want to be efficient you could change to rectangular magnets.
I have a bricked touchstone I will tare down and photograph so you can get a good idea of how it's configured without risking one of your own. I feel my description isn't very good compared to a photo.
